Fu3g0 e60 523i Pre-FL
Re: Fu3g0 e60 523i Pre-FL
- Project 545i - Part 2
Collected the caliper.
Thanks to bro Jonathon for helping me w this lousy budget project.
Really a good job done!
** i got a wrong set of disc (Brembo disc meant for e63 645i) initially. Halfway tru the fix up, realised the diameter might be the same but the hat thickness is different.
Went back back to Eng Soon and got the Zimmerman 545i disc
Disc rotor
(Front 348 x 30, Rear 345 x 24)
Removing the boxes
Front disc w protective paint
Stock rotor n new rotor compare.
The 545 rotor is abt 10% bigger.
(The wrong Brembo disc)
545i front caliper
Stock caliper and 545 caliper compare
(Sorry for the lousy pic quality. Trying my best not to blk their way)
Surprisingly, 545i caliper is so much bigger than stock. Almost 40% bigger.
Stock front cliaper
Front completed.
Finished work w rims on
- Project 545i - Part 3
The rear cliaper is slightly bigger than stock
545i Rear Caliper
Stock and 545i caliper
Stock cliaper w rims
(Take note of the space between disc n dust cover)
545i rear caliper n rotor up
(New rotor cover whole dust cover. Just nice. Dont need to cut)
Rear finished work
Conclusion, the size really looks bigger and nicer than stock. Hvnt got chance to test fully.
For those keen to try urself, best give them the vin num of the caliper when ure getting ur disc n brake pad.
Brake hose can reuse.
Lastly, pls get ur mechanic to check the calipers before u do anything. Easier to repair the caliper before fixing up.
Repair kit can be purchased separately.
I chose the 545i instead of m5 cos the cost of disc is 4 times cheaper but as 545i model is not available in sg, getting parts might b an issue (FYI).
Red_Bean_Bun;1048368 said:
Rotor you never get with cross drill ?
They only got the front. Cost almost 400 per pcs. (4 times the price of this)
Rear no stock. So just take first lor. .
Red_Bean_Bun;1048376 said:
Overall your ride looks quite good ! Very distinct when on the road.
Thanks bro..
Like that also dangerous.
Kana spotted in some places means die. Cannot run. Lol
Well done. Looks great and it has a better performance than the stock
Awesome project......
keep it up.................
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
fu3g0;1048378 said:
Thanks bro..
like at some Hotel................
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
79kingbetcom
