try getting a recon valve cover may be alot cheaper.
i just changed mine at woodlands for $520.
wt_know;1002267 said:
i am facing the same problem.
gasket replace twice liao and oil still leak from the top right at the cover
next is to replace the valve cover liao ... :(
My turn to kena....pui
Was away 10 days for vacation..when approaching my E90... saw a big pool of liquid beneath the car... touch it and found it to be very oily.. . Start the car n check oil level... game over... it was barely one notch above empty.
And before that.. it was full..
Time to see car doctor liao...hope the damage to be
wt_know;997593 said:
can check out R2D ...
280 Woodlands Industrial Park E5, Harvest @ Woodlands, #03-45 (S 757322)
open on saturday ... call first
Provided you can stand their "attitude"....
That's sounds like a very bad leak..... Get it sorted out as quickly as possible. Oil leaks are usually small matters - change gasket here, replace seal there and usually no problem after that. But running an engine low on oil is potentially disastrous!
rvt;1002872 said:
If that is true, that is what I call a BMW specialist, instead of unscrupulous salesman.
Can PM contact?
Yes, I've been using them for awhile now. Never ever had a hint of trying to upsell me anything more than what is necessary. They are BMW specialists indeed! So specialised that when I took my friend in his Renault Megane there, they were kinda unfarmiliar with it... hahaha... So eventually, my friend went to another workshop instead. Not that they were no good - they were just being honest.
Many of the bros here will know that my car had a severe oil leak some time back and I went back a few times to the agent to get it fixed without avail. 1L per day and it was a horrendous experience. I turned to Rod for help and he fixed my car in a few hours what the agent couldn't do in weeks. Aside from the oil leak, he also rectified in 5 minutes what another electrical workshop couldn't fix in two days.
To OT from this thread, their knowledge is solid and their attitude is sincere and honest. They are a small outfit and perhaps you spoke to them at a busy time (was it iDrive or something?). But hey, I think Rod is a really swell guy and I enjoy each and every trip at R2D knowing that my ride is in the best of hands.
I can't vouch for Rod as I've not personally used him. But over and over again, I've been hearing nothing but good things about him. So I believe that probably was an isolated incident? Maybe he kanna PMS that day? Com'on! We all have our own bad hair days too, don't we? =)
To OT from this thread, their knowledge is solid and their attitude is sincere and honest. They are a small outfit and perhaps you spoke to them at a busy time (was it iDrive or something?). But hey, I think Rod is a really swell guy and I enjoy each and every trip at R2D knowing my ride is in the best of hands.
Can anyone send me the jb workshop address that Oscar recommended?
I have some coolant, radiator and engine oil leak issues, are these 3 things a common problem?
Thanks!
hi guys, side-track a bit...
is gearbox a common problem for 2007-9 320i ? looking at getting a used one and first time trying bmw...
thanks..
yes, especially after 100,000 km mileage
thanks..
so in the event gearbox issue, what options are there? new replacement? damage? recon part available? damage? any WS that could repair and the damage? hey thanks for advice...
spend sometime to read all the replies in these few threads and you will have all your answers
gearbox issue
http://www.bmw-sg.com/forums/bmw-3-...lenoid-change-jerking-problem-solved-e90.html
http://www.bmw-sg.com/forums/bmw-3-...erhaul-transmission-sep-2006-e90-320-pfl.html
gearbox & common wear and tear issue for above 4-5 years old e90
http://www.bmw-sg.com/forums/bmw-3-series-owners/54580-my-e90-320i-repair-journal.html
Dear Bros,
Need help! It's regards to the engine oil error code I've been experiencing every week. Every 5 days to 1 week the engine oil logo will just flashed out.
Sent to dealer workshop to diagnose, popped up the bonnet.. no oil leak detected at the engine bay. Therefore the mechanic ask me to try a better thicker engine oil as my ride is 2005 mileage abt 180,000km. Previous owner already did an engine overhaul as told to me by the dealer.
After a week changing to the better thicker engine oil, the same problem arise, the EO logo flash out again. So I went back to the workshop again. This time round they changed the oil slump gasket to fix up all minor leaked as well as coolant, transmission oil.
After a week, same thing happened again.. The EO logo popped up again. I did my own EO top up..
The EO logo just keep popping every 5 days to 1 week...
What could be the main problem? Can't be topping up the engine oil every 5 days..
Please advice... Any solution that can stop this EO Issue? Really appreciate it very much.
spartan-lee;1012977 said:
Dear Bros,
Could be the valve seal harden up. I used to have this problem last time. After replacing the valve seals and the valve cover gasket. So far,there's no problem with engine oil. Prices for the repair can vary and costly. But you should try finding your dealer again if there's an internal liability period.
replace valve cover gasket and valve seal :thumbsup:
http://www.bmw-sg.com/forums/bmw-3-...hange-white-smoke-problem-solved-bmw-e90.html
Dear All,
I seem to have this problem but mine will pop up every once a month to ask me to top up engine oil. I have change almost all possible things
1) Oil Filter Housing O ring 1
2) Oil Filter Housing O ring 2
3) Valve Gasket Cover
4) Valve Tronic Gasket
I have the my car check by mechanic, they claims that engine is eating oil with no apparent leak. I presume the next step is engine overhaul, but I think it is cheaper to added engine oil for the next 2 years than going for engine overhaul. Any other advise as I have spend around 2K trying to sort the problem
KT
ktak888;1013346 said:
Dear All,
KT
How about the engine valve seals? You could go JB to do the repair.. Parts buy in Sg.. Won't cost much.. Refer to Aaron's thread.. It worked for me
chinweyngee;708016 said:
today I chg front brake pad (390)+sensor(45) & rear brake (350)+sensor (45), workmanship is front (30) & rear (30). Did in KL for RM890. Hope is helpful for benchmark.
Bro, can send me the details of this workshop in kl.
