battery in the trunk for 335
Re: battery in the trunk for 335
centurion;275828 said:
BMW started it all with the Turbo thing. The 335i has changed the face of BMW mods more than any model in the past decade. Because it's so easy to start modding the 335i with BIG payoff, so people get bitten by the bug and do all kinds of crazy things.
After you pick the low lying fruit by upping the boost and kickin using piggyback ECU, then the other fruits are harder to pick. You do the suspension, wheels, etc. After all the mid-lying fruits picked, you will do the crazy things.
Battery relocation, seat changes, stripping the car, etc.
you are a genius,couldnt have said better myself.
centurion;275839 said:
really, BMW opened a can of worms with an inexpensive Turbo car.
Already, see all the BMW forums in the world today. Change to like ... STI and Evo forum liddat ... shocking!
Thats why, lets not turn our 335 into STI/EVO leh:lol2:
I am a simple beng, all I need is a 3rd turbo:)
Darth Vader;275719 said:
NEW PRODUCT FOR 2007
B3121 No-Weight Extreme Battery Specs
Weight: 21 lbs
Length: 6.6
Width: 5.2
Height: 6.8
Pulse Cranking Amps: 1380
Cranking Amps: 742
Cold Cranking Amps: 550
Amp Hour Rating: 31
Warranty: 1 Year Free Replacement / 2 Year Limited Pro-Rated Extended Coverage
Recommended Uses:
Premium Luxury Vehicles
Extreme Engine Builds – High Compression, Supercharger Systems, Large Cams, Underdrive Pulleys & No Alternators
Extreme Audio Builds – Multiple Amps, Subs and enough wiring for a small city? You need this battery! Extreme Cold Climates – Daily Driven or Stored Vehicles
Custom Cars and Vintage Vehicles – No Acid to Spill protect and enhance your vehicle!
Not Recommended For:
Any vehicle you don’t want to look or perform better!
Customers looking to save the most weight on a small displacement purpose built machine – check out the B106 or B14115 Carbon Batteries.
i believe the amp hour for stock bmw 52 ibs battery are 80ah or 90 ah.not sure 31ah is enough or not.
how much is the battery ah darth vader????
Darth Vader;275886 said:
us$200 for normal casting. us$250 for carbon fibre casting
wahaha...so ex ah! do they sell in s'pore? can fit E46? i drive E46! is my battery in E46 heavy?
Exquisite Marques,tel 65421151.
I did weight my battery before. Although its not 20KG, it weights 17KG. Its rated at 72AH 550A.
hackzi;275848 said:
3 lbs battery anyone?
Voltphreaks - Home
Wow USD400..........
From what I have read, every 40KG can shave off around 0.1s from your 0-100KM/Hr timing. Even if you can run you car w/o a battery, you can at best improve the time by 0.05s (assuming its linear improvement).
This is to say that it does really make a difference to have a light weight battery inside the car unless you are using the car for racing purpose.
