battery in the trunk for 335
Darth Vader
hi folks
i found out that the battery for 335 is located in the right hand trunk.is that true ?
i read that it weighs 52 ibs.a lot of people changing to light weight models weighing less than 20 ibs.thats a weight saving of 32 ibs.
and also our fuel tank is in the right hand side.so this 32 ibs weight saving will make our car more balanced.
for LHD cars it will make them off balance a bit.
have anyone changed their stock batteries ? where can i buy light weigh batteries ?
Re: battery in the trunk for 335
if you are so worried about weight savings, try taking out the air con la.
I bet you can shed off a few more pounds off your self too.
Where got battery 52 lbs??? Can follow STI spec C, then the car will be lighten a lot. and driver need to lose weight also.kekekeke
Its true that the battery is at the rightside of the trunk, below your tools but I find it hard to believe that the batt is 52lbs... that's like 20.8kg!! No wayyyyy....
seriously man.a lot of guys weight their 335 battery in e90 post.all said at least 50 ibs.one guy measured 51.8 ibs.
i am going to take a look at mine when my car arrives.
just found a singapore distributor that deals in light weigh high capacity batteries.gonna call them on monday.
Just bcos of few lbs and you want to change the battery, you will have plenty of items to change. You should just leave it, small matter.
I gues the 335i battery has been specced to make ready for `no charge during acceleration' feature which debuted in the M3 - they share the same battery.
But the 335i AFAIK not yet has this feature. However, I read 2008 models will have this, but what constitutes a 2008 model year car for BMW I am not sure.
Once this feature is in, you must use the big battery, otherwise, you will not get enough charge.
A high capacity Orion cylinderical cell battery may be able to do the replacement, at 19-25lbs depending on capacity.
I stand corrected but based on BMW production cycle, I am given to understand that those manufactured 3rd quater of 07 onwards is considered an 08 model.
i think barry rex7vtec has some lobang for a good lightweight battery. can ask him about it
the dilemma faced by most people would be = would a reduction in weight overall be worth the balance alteration? Anybody can address this?
for RHD cars a lighter battery is good news.cause the oil tank,battery and driver are on the right side.the battery actually sits quite high above the axle.so less weight on the right hand side is good for RHD.for LHD it may not.
Overwhelming reason then to change to a lightweight braille lightweight battery or something. Oh god, what was BMW thinking? Make it so easy for people to improve the car = engineers not thinking at all.
the braille battery weighs 21ibs.there is a local distributor here.
Compatible capacity to stock battery? Price? Warranty? Look forward to your update DV.:)
NEW PRODUCT FOR 2007
B3121 No-Weight Extreme Battery Specs
Weight: 21 lbs
Length: 6.6
Width: 5.2
Height: 6.8
Pulse Cranking Amps: 1380
Cranking Amps: 742
Cold Cranking Amps: 550
Amp Hour Rating: 31
Warranty: 1 Year Free Replacement / 2 Year Limited Pro-Rated Extended Coverage
Recommended Uses:
Premium Luxury Vehicles
Extreme Engine Builds – High Compression, Supercharger Systems, Large Cams, Underdrive Pulleys & No Alternators
Extreme Audio Builds – Multiple Amps, Subs and enough wiring for a small city? You need this battery! Extreme Cold Climates – Daily Driven or Stored Vehicles
Custom Cars and Vintage Vehicles – No Acid to Spill protect and enhance your vehicle!
Not Recommended For:
Any vehicle you don’t want to look or perform better!
Customers looking to save the most weight on a small displacement purpose built machine – check out the B106 or B14115 Carbon Batteries.
i believe the amp hour for stock bmw 52 ibs battery are 80ah or 90 ah.not sure 31ah is enough or not.
firstly, there is no way even a standard off the shelf battery weighs 20kg, not possible
What you have to look for is CCA (cold cranking amps) I would suggest at least a 550, which means its an 11 plate battery, perfect for 4 potters. 13 plate is the go for 6 or 8 cylinder cars.
Get a dry cell, like an Optima, they are low weight. Although, im still confused as to how a battery weights 20kg, thats almost a bag of cement!! Unless it's a truck battery.
