Vibration issue
Re: Vibration issue
1M got fault...bring back to MA for them to diagnose / fix.... anyways they have the 5 years warranty thingy to cover the car.
besides, the car is stock....
maybe navi can ask for courtesy car... then jio meek for ///M5 test drive.....
Re: Vibration issue
Navi;1052130 said:
I didn't do anything to the car. It's stock. :)
then most probably it is due to coils or spark plugs :)
Re: Vibration issue
I just hope they will find out what is causing this problem and solve it.....I miss my car =( I will ask what went wrong and update you guys again =)
Re: Vibration issue
update: problem found one of the valve on the 6th cylinder is jammed.... got to wait for parts to be ordered and delivered before repair can be done. time given was 1 to 2 weeks.......
Re: Vibration issue
Since going to reach in there to address valve issues - maybe can ask them to clean up the carbon there along the way .......
Re: Vibration issue
They won't auto clear de? XD initiative mah lol.
Re: Vibration issue
Curious to know if you mean the valve in the cylinder head or other valves? How stuck is stuck? Did they do a leak down to determine the fault? I am curious to know because I had an experience in the past with a stuck valve that is only about 1-2mm stuck and the result is a bent valve. That was on a motorcycle engine. That is how tight the clearance is from the valve to the piston crown. Interested to know how they know its a stuck valve.
Re: Vibration issue
No idea man I just repeated what I was told lol. Don't really care liao they fix swee swee can le. XD
Re: Vibration issue
After they clean it ..... Install an Oil Catch Can .....
Along the way ask them to check the solenoid valve for good measure.
