Rims - how to tell the real from the replicas?
Re: Rims - how to tell the real from the replicas?
From past history, i think that looks should take a backseat when you buy rims. The looks of the rim with respect to the car is not as important as how well the rims hold up when you hit an object.
IMO, save up until you can afford a set of forged rims which gives you the best combination of performance and strength. Next up are good quality cast rims like OZ, enkei.... you catch my drift. Replicas made by dodgy manufacturers are risky cos they may use 2nd casting aluminium alloys that are more brittle and are prone to cracking when they are subjected to impacts.
1st casting are made from alu ingots that are mixed to form alloys and poured into casts. When cooled, the rims are further trimmed, milled and ground to finish the product. All the cut off material is collected and remelted to form alloy ingots to be sold off or recycled... usually it is these stuff that smaller rim companies buy to make their rims.
Very valid, especially for a fellow forumer who has a cracked replica rim after an accident. Apparently, he has to change the entire set of 4 because the replica rim is out of stock......
To reinforce what has been said above...there is a small section in the current BMW Car Mag on replica rims which were destroyed as part of law enforcement exercise. And the rims in the pix were all AC Type IV...the most copied of all...
Orh LuLu said:
Not too sure are there replicas for all brands but for sure the brands u mentioned, there are replicas around... By the weight, serial number behind the rims and certain part of the rim against the original can tell... well, also depends where u get the rims from, for sure u will not see ACS replicas from PML... for sure u will not see Breyton replicas from Juzz4cars... Hamann from Pheonix..
Its like distinguising an original and replica boob like that.. method is the same.
Wah lau eh.. you mean to rubba rubba the rims to distinguish ka?? kekkekeke....:lol2:
