Rattles unavoidable?
Re: Rattles unavoidable?
bkelz;868575 said:
Cool Bear... you tried the spray?
Nope, tml call pml to check if they have :)
okay! who wants a btl of BMW Gummi PLege?
i am going to get it.. its $13 something cents... they have in stock. who want let me know i can help get it.
realized that BMW Gummi PLege has been replaced by Carbaflo (teflon based) ?
Part no 83-23-0-309-627
Carboflo has replaced Gummi-Pflege - E46Fanatics
http://www.carbaflo.com/fs.htm
Product name: Carbaflo® XTR materials
The Carbaflo® XTR materials are a range of fluid
coatings developed for use as interface materials
for the prevention of squeaks and for the
promotion of smooth movement in automotive
interior trim components and sealing systems.
Chemically similar to the first generation materials
including the Carbaflo® KSP fluids, the XTR
materials feature an extended operating
temperature range, improved durability and even
lower volatility. The Carbaflo® XTR products exceed
the requirements of the automotive industry with
an extremely wide operating temperature range
from below -54°C to above 220°C.
Carbaflo® XTR5
Carbaflo® XTR5 fluid is an odourless colourless
liquid fluoropolymer coating requiring no curing
and can be applied to any substrate material
without compatibility concerns. It also exhibits
improved film ‘lay down’ characteristics and is
easier to wipe or spray onto surfaces than first
generation materials.
I had the same problem with my Z4. I brought it back to PML cause it was under Warranty and told them to tighten and change the bolts in the panels. been abt 2 months and the rattling has not come back yet. After doing this the noise reduction is also amazing .
my rattling is on the driver side windows.. cliak cliak cliak.. very irritating..
My rattling is from wife mouth
Cliak cliak cliak too
Very irritating too
Esp when discussing abt 19" rims, bbk, eisenmann etc
Will this work?
dun think u can use silicone to solve ur rattling issue.. need superglue :p
Very irritating too
Will this work?
Masking tape???
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
Hmmm... shall do the same next time I'm back for servicing!
I faced the same problem with the squeaking sounds until I replaced all the rubber seals on my Z3 - M54B22. It is quiet now and a can of the teflon lube should help me maintain the seals better. ..... just wondering if owners of Zs meet for night topless drive?
I can't tolerate minor sound inside can. I'll make sure I dig out the problem n get it rectify but then some can't be avoided
I reckon the best way would be trying to isolate vibrations from interior panels. However, all topless cars due suffer body scuttle due to inherent chassis weakness.
I'm trying to tackle this problems after i install my new top. The other option is putting the hard top back on if you have one.
bring your Z3 to meet up later........
cheeeeeeeeeeeeeeeeeeeeeeeers
I cannot make it for this one but surely will for the next!
