ac323;488357 said:Congras man.........
vroom vroom
CK64;488527 said:Ya, air scoop from r2d the next since the bros here recommended that it is cheap and good![]()
(I tried to get the Simota Aero Form intake from another bro here but decided not to proceed since further modification is needed for my ride.)
dreammaker;489806 said:I realised that the fuel consumption went up from 10.2 to 9.8 per litres after I installed the ignition upgrade and air-scoop. This is despite going very easy on the pedal. Any other bros experience the same?
R2D;493814 said:The law of conservation is still applicable, this mod also follows physics. Actually, with a quicker burn, the engine block traps more heat (due to longer time the hot gasses stays in the engine) as the exhaust gas temp goes down slightly.
But in actual fact, the cooling system can handle the slightly higher heat energy easliy.
As for the increased fuel consumption, my guess would be either changing traffic patterns of the scoop. I have noticed higer gas flows from the MAF readings with the scoop. Wanna remove the scoop to verify?
ac323;501027 said:yup yup,
MTL.................
vroom vroom
