jylam
Re: Auto Transmission (symbol of exclamation mark inside a circular gear
+1
My previous ride, E90 110,000 km, experienced the problem of loud thud and jerk forward when coming to a stop. Initially thought the gearbox kaput but with the recommendation from a workshop, I changed the ATF and filter.. After that problem solved.
Lifetime ATF is bullship, we shld change it every 50k (may be)
Derrrick Yap;641742 said:I would suggest you guys go for an ATF and filter replaced. It should be leaking and the ATF is low n that y the warning came on. Mechanical parts in the gearbox is very strrong and will last for more than 300K with regular ATF change.
Most owmer face gearbox problem in olden days is becos PML claim that the ATF is for lifetime used.
Oil undergoing temperature will sure to deterate and looses it vicosity hence not providing sufficient Lub to moving parts n ended up some things will have to give way.
+1
