WTS: DINAN Stage 3 Suspension Kit for E90M3 (Works with EDC)
Dre
Hello guys,
I'm looking to sell a used set of Dinan Stage 3 Suspension Kit for E90M3 (with EDC & compatible with both Competition/non-Competition Series). Kit is in excellent condition. Price is $2k. PM or whatsapp to me at 98431011.
DINAN is a World Leading Manufacturer of BMW Performance Upgrade Products and Engine Tuning Software. Dinan’s comprehensive warranty program, introduced in 1996 with the cooperation of BMW of North America, provides BMW owners with matching coverage to that offered by BMW’s new car warranty, ensuring that Dinan® performance enhancements and the BMW they have been installed in are covered for up to 4 years or 50,000 miles. BMW automobiles can now be performance-tuned without the associated concern of negatively affecting the new car warranty coverage, making the idea of enhanced driving fun and excitement appealing to a rapidly growing number of BMW drivers.
This kit dials out the understeer inherent in factory cars. Turn in is sharper and there's significantly more front end bite/grip. There is more overall mechanical grip & none of the added discomfort associated with many other aftermarket spring/coilover setups. Ride remains plush. Dinan is very comprehensive in providing suggested alignment & tyre pressure specs for both street and track use. The kit is fully complementary to the factory EDC system. You can still select between Comfort, Normal & Sport profiles.
A plug n play solution for E90M3 owners looking to improve their handling whilst retaining the ride comfort.
Includes ALL the items below:
Dinan Performance Spring Set (For E90M3)
Benefits
+ Decreased body roll from higher spring rates
+ Lowers the vehicle 1/2" in front and 1/2" in the rear
+ Preset to prevent spring sag
+ Compatible with both conventional and factory electronic shocks
http://www.dinancars.com/product/d1...set-for-bmw-e90-m3/?series=M-series&mid=1113/
Dinan Lightweight Tubular Adjustable Front Anti-roll bar 32mm (For E9xM3)
Benefits
+ Less Body Roll
+ More Mechanical Grip
+ More Stable At Limit
+ Large 32mm size
+ 3 hole bar with 5 possible positions on bar & adjustable length end links
+ Lightweight – 42% lighter than a solid anti-roll bar of comparable stiffness
+ Only tubular anti-roll bar with a large range of adjustment on the market
+ Tubular (Hollow) Construction
http://www.dinancars.com/product/d1...w-m3-e92-2008-2013/?series=M-series&mid=1113/
Dinan Camber Plates (For E9xM3)
Benefits
• Shifts Stock Adjuster
• Drastically Improved Mechanical Grip During Cornering
• Reduce Understeer
• Up to -0.7 Deg More Negative Camber
http://www.dinancars.com/product/d1...bmw-m3-e90-e92-e93/?series=M-series&mid=1113/
Dinan Supplementary Ride Quality & Handling Kit (For E9xM3 with EDC)
Benefits
To fully enjoy Dinan® performance spring sets we highly recommend pairing them up with our supplemental ride quality and handling kits. This additional kit includes tuned, progressive rate bump stops that maximize suspension travel on the lowered car for improved handling capabilities and ride quality when compared to just a spring set. In addition to the bump stops this kit includes front guide supports that increase available suspension travel by 3/8" and Dinan rear shock mounts that provide an additional 1/2" of shock travel for improved ride quality and performance. By allowing for full compression travel within the spring the possibility of a sudden "bottoming out" is negated, a common unwanted side effect when lowering a vehicle. Bump stops also have the added benefit of optimizing the spring rate rewarding those that use them with added mechanical grip and cornering power. Simply put, the Dinan supplemental ride quality and handling kits amplify performance and comfort when paired with performance spring sets.
http://www.dinancars.com/product/d1...w-e90-90-93-m3-edc/?series=M-series&mid=1113/
