Wisdom tooth
Re: Wisdom tooth
wisdom tooth op can keng how many weeks of MC? if do 1 by 1... can take consecutive weeks of MC?
Re: Wisdom tooth
Bling;1028257 said:
Are you handsome?
huh...arh...I m a dentist, why ask me handsome a not?
Re: Wisdom tooth
YES...I can chut MC for u
Re: Wisdom tooth
Bling said:
Was your wisdom tooth visible when u decided to take it out? And thanks a lot, the text in bold u mentioned helped me to feel more comfy about this! Im gonna call that clinic and check out more details
Anyway then what about the other pair of wisdom tooth? No intention of removing them?
Not visible, bottom one near rear molar. The other pair, they said not yet, cause not interfering with current teeth.....
Bling said:
Are you handsome?
He is very hamsome.
But you have to drink a few glasses first.
Re: Wisdom tooth
kenntona; said:
I think it was 2 weeks on porridge. I lost 4 kilos.
Lost 4 kg of weight is a tiny fraction for hippo leh.... mw say one
Re: Wisdom tooth
Piss off lah, Chicken King !!!
Re: Wisdom tooth
arh here...chicken king! is a good phase to use...
pronounce as kuay ong! in hokkien!
but in Cantonese.... u dun use kail wong! u use kail cong!
take note jasonmaxima!
Re: Wisdom tooth
Arsenal62's surname is ONG.
Re: Wisdom tooth
jonleeck ur spelling is worse than a Primary 1 kid
Re: Wisdom tooth
He is very hamsome.
Omg, mine is visible already!!!! Thanks a lot for e precious info!
Hmmm i think besides that i need to put my glasses away too
I need to create a thread after i remove my wisdom tooth and must post the picture of a handsome dentist...more palatable...i mean presentable to be shown on bmw-sg
Re: Wisdom tooth
Please give respect. He graduated from Chao Yang University with first class honours simmi cum loude. Mai sng sng.
Re: Wisdom tooth
The wisdom tooth op should be fine.... usually the dentist would use L/A... local anesthesia to numb the area when performing surgery.
For the more difficult wisdom tooth extractions, some dentists would use G/A... general anesthesia....before performing surgery to remove the tooth.
Its the recovery period that is the painful process where soft foods like porridge / pureed foods are consumed. Since you have raw wounds with stitches to heal.....
Re: Wisdom tooth
fine...how u spell chicken in Cantonese?
Re: Wisdom tooth
Culinary chicken = kai
Steamed version = pak zham kai
Cunninglingus chicken = kai
Fair cunninglingus chicken = pak zham kai
Cunninglingus chicken from China = pak gu kai
Re: Wisdom tooth
Thank you.
I heard about the LA and GA...thinking about LA im really scared, like i would be able to witness the whole process...but if GA is required it is also scaring me because it means it is more complicated.
Where did u remove yours?
Re: Wisdom tooth
yah its either kai or gai...
simi kail.
Retard
Re: Wisdom tooth
What is kai kai then?
Re: Wisdom tooth
You very funny. Didn't you ask for handsome dentist?
Re: Wisdom tooth
Before the op starts i need to communicate with him and perhaps take a picture with him mah...and then if it's GA i will wake up to a handsome dentist, it would be less painful i believe... If it's LA then at least i get to watch a handsome dentist removing my wisdom tooth...
