What's the widest tire the E46 can fit?
sturtles
Hi guys, like to find out what is the widest tire size the E46 can fit for 17-19 inch rims with 3 finger gap from lowering?
Thanks!
Re: What's the widest tire the E46 can fit?
For E46 Non-M - Rear can go 19" 255/30/19 no rubbing! This will be based on the standard offset for the E46 which I believe is +42 for the rear.
265 will require fender modifications. Still can squeeze but be ready for rubbing over humps or car with pax.
For the ultimate, you can go to Mike and get your rear Cut, Widen and re-modified to M3 rear flare specifications! Then, you can squeeze 285 too. Swee Swee!
huh? why do you wanna go wide(255/265) in the front? That will be a joke not to mention a formula for disaster!
and no, it will not fit.
If you want to make the front look more aggresive, then add spacer. But people do that to clear bbk. Proper way is to get proper offset rims to fit your car when you wanna play staggered. I learned the hard way and wasted tons of cash on freaking 19's and 19's and spacers and spacers.....
Don't waste time. Just go 18X8.5 and 18X9.5 - 235/40/18 and 255/35/18 respectively...Staggered (proper offset) w no fender mod required.
Peerrrrffect!
Well, I was so jealous when i saw this...
It has a plastic wide fender kit for the hugely wide front tires
Are there any front wide fender kits available for the e46 that is not very obvious the rov guys?
Thanks bro
Sturtles
Further to the above clarification from BS...
U need to be sure of what rims width you're running.
Most people have 8 or 8.5J all round...only a few go staggered set up.
FYI, 8.5J can max out to fit 255 tires front or back while 8J goes with 245 max
Some people who are in serious tracking puts on 265 on 9J rims in the front set up to get better grip and reduced understeer.
In my experience, 255 on 8.5J seems a bit too wide tho fit-able...225-245 are good enough.
255 will be perfect on 9J whereas 265 on 9.5J :)
Follow the tire manufacturers chart and u can't go wrong
U can go wide body but it's illegal..
Lumna makes it but it's bit too loud..go google:)
Thanks M!
This is the luma kit, and ye, its too showy, and much too wide... somehow the original e46 front fender suddenly looks nicer
265 for the front... is it possible, with the correct offsets on e46?
Brother BlackStealth, for the 235/40/18x8.5 and 255/35/18x9.5, what is the offsets for the rims? if this is the max width the car can take, this should be a better option than 19" as it gives more comfort and cheaper on the tires too
For 235/40/18 8.5J, u can get rims with offset between +35 to +46 and fit w/o any problem.
For 255/40/18 9.5J, lowest u can go is probably +38 on the rear and max out ard +42.
TripleM said:
For 255/40/18 9.5J,
Yo Jack wheel master! Dun mean to second guess you le but 255/40?? I thought 255 is 35?
Haha of coz 255/35.........typo.
wah, whats the damage to widen the rear flares and front? was yrs widened?
i got mine done.... folded and rolled the rear fenders...
no scrubbing.... even on my 19"s
Pm-ed you.............................................
Hi Eddie, are you on 265 rears? cause rolling alone just might not do it.
BS,
i swapped down to 255/30.... i was rubbing like crazy on the 265...
they wanted me to shave off the entire lip... i was a little worried....
I went with M3 18's, rear 255/35 (pirelli Pzeros), and I having problems with them making contact with the rear wing.
