What causes throttle lag on a naturally aspirated car?
centurion
On turbos I understand, and even then, the throttle lag should not happen on the low end. On NA the usual explanation is ... electronic throttle to blame. I would like to blame it on the electronic throttle but really, electronics can be made really fast. I'd really like a real explanation on the throttle delay felt on today's cars. In fact, throttle mapping can easily bias towards low pedal angle and eliminate the throttle delay totally. Is that the flywheel? Is it by design? Is it that the ECU has to wait for the air mass sensor before it dare to press on?
The F430, R8 has NO THROTTLE DELAY whatsoever. The old Porsches all the way to 964 have no delay. Hell the S2000 has no delay.
But the Cayman has a very slight delay. The BMW 325,525 have lots of delay. The old 30 engine, even in the 630 application, is between the Cayman and the 325 in duration. The 3 valve 2.6 Merc engine and the new 4 valve 3.5L Merc engine delay like can grow a beard.
WTF? Can we just hardwire the AMS to give the `correct' output so that our throttle no delay?
I'm almost gonna change the flywheel because of this. That will ASSURE me good throttle response, at the expense of traffic jam driveability. But before I do that, is there anything else I can do?
Re: What causes throttle lag on a naturally aspirated car?
i thought a sprint booster will correct that ,no ?
i have read that many manufacturers make the first inch of travel to have a delay for safety. i think its stupid. if u cant modulate your right foot you better dun drive. but i do not think this is a lag that you can compare to a turbos lag.
sprint booster is a e-throttle remapper basically... no. I've tried those things on a bmw and all it does is the shift the throttle map to the left, much like Porsche Sport Chrono sport mode. There is lag still, but then with slight press you get more throttle. The problem with this kind of fix is that on low rev driving, eg. traffic jam, smoothness is harder to get from a clutched manual.
retrofit the throttle by wire with a mechanical one.perhaps older e36 comes with mechanical throttle.
problem is I don't believe that throttle lag caused by inherent issue in e throttle. Because I feel some e throttle cars, some no lag!
even with mechanical throttle, there will be slight delay, cos can always improve response with individual throttle bodies, intakes, playing with the internals, etc etc etc....
Cam phasing is to blame.....current emission standards mandate that during little throttle openings, the overlap is reduced to minimise the cross flow of intake charge into exhaust.
any product to get rid of this cam phasing issue?
I don't mind buying multiple free flow cats ...
I dont think this has anything to do with any free flowing mods. AFAIK, even for BMW cars, those with the hesitation got theirs solved thru a progman update aka ECU update by the dealership. Your throttle mapping is inside the ECU and the sprint booster does nothing but to bring the throttle position sensor to a more closer range that makes the car appear much more responsive. What you need to do is get a software update for ur car.
Nope... unless you can lock out your cam phasing equipment (D Vanos, VVTI, I-VTEC....) and bluff your ECU (cos when the ECU does not see any movement in the cam phasing, its gonna throw a fault code). So with stock ECU's there is really not much that you can do.
First time I've heard of throttle lag on a NA engine. I had always thought of the problem being unique to turbo cars. My 330i has an e-throttle, but it has no detectable lag at all. Put your right foot down, and the throttle immediately obeys your command. With the TT, I could plant my right foot, and go away and make a cup of tea. When I come back the car (also with e-throttle) is still deciding whether to move off. OK, I've exaggerated a bit but you know what I mean.
what I meant is that, once I modify the overlap for the cam phase, I will get more emissions, to save the world, I will change cat to multiple free flow cats to clean up my emissions some more.
it's not as bad as i put it. But after some time in an old 1978 Honda Civic car recently, only then I felt that my current throttle not as responsive. Before that, I thought I had a lighting fast throttle response.
might be partly due to the weight of your engine's internal components as well. maybe lighter pistons, connecting rods and crankshaft?
Too light a flywheel will give you a lumpy idle.
Is the time required to open the butterfly or butterflies in the throttle a possible source of lag?
my take?
the first few mm of throttle travel as well as sensitivity are electronically "dummied" to eliminate bunny hopping on uneven roads.
when i have my car in "normal" mode, but driven relatively aggressively, any uneveness in the road does not really affect the throttle response - when the car bounces up and down causing your foot/leg to follow the bounce affecting the throttle opening. This is because the throttle is "slow" to response to inputs.
however, when i have my car in "power" mode, there is no lag, but the throttle response is so sensitive that road uneveness that results in bunny hopping (without a heavy determined right foot) causes the car to surge back and forth.
conclusion imho - comfort and driving ease for 99.9% of car drivers.
solution - software upgrade.
edlms;315623 said:
my take?
that's a good idea ... at least now I know why they dumb down the software, justifiable.
I hate the hopping. and find that no matter how sweet the software upgrade, something is wrong with it at the end of the day. think I'll live with it.
One of the reasons I gave myself was that engines are getting much more powerful and responsive nowadays and the lag was probably done to reduce foot and ankle fatigue. Also partly due to the slow reponsiveness of auto tranny which hasn't had much advancement compared to the engine.
Anyway, how about removing all the environmental friendly devices? That would make the car run alot more raw wouldn't it.
