What can I do to a E60 (Pre LCI)?
dan5959
Hey All,
I just collected a pre LCI 2005 E60 left with 3.5 years. It's my 1st BMW. Have driven a VW for 4 years but decided to get this to drive till the end of life since mileage was very low.
I would like to do certain things to spruce the car up. Could you all advise what can i do in terms of the following aspects? I have read through the forum for the last 2 weeks but still feel a bit lost. Appreciate all the help and kind advise. :)
1. Front Lights - what can I do besides changing to LED Angel eyes?
2. Tail Lights - heard that I can fit a LCI LED tail light. Is it possible?
3. What can I do about the ICE? Would like to be able to play DVD, install a reverse camera since my wife drives 50% of the time and perhaps GPS. Does fitting all of these give an issue to the existing unit?
4. Solar films - would like to give the dark look (that I see in most E60s) but effective IR blocking
5. Any other suitable recommendation is also welcome
Thk you everybody for your kind attention and advise in advance.:D
Re: What can I do to a E60 (Pre LCI)?
dan5959;799887 said:
Hey All,
Hi dan,
welcome onboard...................
Hey bro mine is a pre lci e60 too, ive installed a set of white angel eye from bimmershop which really brings out the look of the ride especially mine is white. Remus exhaust, you'll enjoy a bassy exhaust although some drones is unavoidable. Definitely sounds sportier with the sport exhaust... But recently considering making it louder... Haha. I wonder how? Installing a set of 19" rims and a set of chio chio bodykit can definately turn some heads on the road. Some bros here say damage for ice with gps will cost around 2 to 3 k . So for my case I leave that out since left with 3.5 yrs. Get those external gps will be fine...
Hi dan Welcome to E60 club...
You can change almost anything bro. Make it a Yam!
Welcome dude! Many things to do for e60!
LCI tail lights I believe fit exact but are not cheap, even the Taiwan made ones.
ICE is also in the region of thousands for sure.
Bodykit and 19" are a MuST! Hehe
I also wanna get some advice on solar film.. If put dark dark inspection confirm fail right? I wanna change dark ones too since my inspection only due next year. At most inspection time change back normal then past back again..
change to LCI tail lights require a adaptation module.. not cheap.
Mine is dark solar too... When time is up.. I get my mechanic to drive in for inspection.. So I think most likely will pass
You can do the following by clicking here:
http://www.bmw-sg.com/forums/singap...our-bmw/55536-wts-my-strawberry-e60-525i.html
Exterior
Dressed in Lamborghini white
Kerscher-modified front bumper
M-tech side skirts
M-tech rear bumper
Hamaan rear diffuser
AC Schnitzer mufflers
Lumma roof spoiler
M5 side vents with carbon fibre
M5 side mirrors
M5 trunk finisher
LCI front and rear conversion
OEM dark kidney grilles
Shoes
M6 19" rims
Toyo T1 Sport rubber
Performance
Brembo BBK 6pot front 4pot rear with cross drilled rotors
KW street comfort coilovers
Racing Dynamics front and rear ARBs
Powerbox tuned for local conditions
Kelleners engine strut wrapped with carbon fibre
AFE open pod air intake stage 2
Interior
M5 steering customized (flat bottom) with paddle shift and carbon fibre
M3 gear knob sprayed in piano black
Black carbon fibre gear shift plate
///M cube aluminum interior panels
Full interior rewrap in black
///M door sills
Ice
Alpine 502 head unit
Alpine 701 processor
Micro-precision Z-series tweeters
Micro-precision Z-studio midrange
Micro-precision 7-series midbass
Mosconi AS 300.2 amp
Mosconi AS 200.4 amp
Mosconi AS 200.2 amp
Morel Ultimo 12" sub
Digital TV tuner
BolderTech F600 SecureSound
3M Customized Floor and Boot Mat
Dun worry you can use the whole boot space
Since it left only 3yrs, just lower your car and changed to 20inch tyre. :thumbsup:
Golilok.. your ex car si beh tok kong
Exterior
M-tech side skirts
M-tech rear bumper
Lumma roof spoiler
M5 side mirrors
M5 trunk finisher
Shoes
M6 19" rims
Performance
Interior
///M door sills
Ice
Digital TV tuner
golilok;801377 said:
People who appreciate liu qing yun are tok kong
Lol.. Swee. How long you have change your car?
6 mth the f10 is a far better car
Liu qing yun change already super tok kong
This sg liu qing yun not so rich like HK liu qing yun. Will go mediacorp to find a acting job if can be famous. than i join you in F10... :thumbsup:
Jialat not many sg pple appreciate liu qing yun gd luck
