What bulb to use eh??
carbonfac3d
Bro's , if the headlights use H7, what bulbs does the foglights use????H11 is it?? So what is H4?:eek:
Re: What bulb to use eh??
The H numbers are the bulb type. Check your manual, it should be written there. What model is your car? Fog lights can be H8, H7, 9006.....
H4 is in older cars, surely your car wont have.
The foglight maybe H1, not H11.
btw a bulb is something you plant in the ground and grow flower.
Aiyah Phil..not onion bulb arr..
715, I'm using aftermarket M3 foggies
aftermarket foggies then I'm not sure what bulbs lio. If you're thinking of changing to those Philips white bulbs, best way to find out is to go to the shop that you're gonna install, they will take out your existing bulbs and match the right ones for you.
