Wet floorboard on passenger side.
thanks bro. 1 shop told me that the aircon coil is faulty and need to be change inclusive some valve.estimated around 1.6k. will go down to R2d. btw thanks alot.
If confirmed cooling coil then they will charge more
You can call R2D before going
Wet floorboard on passenger side? Likely to be a known problem with F10 - which is the accumulation of water in the left steering column due to worn-out steering column cover.
You will need to get it replaced, and dry out your entire passenger floorboard.
yo bro, problem solve. its due yo the blower cover damage and the aircon filter was miss align by the previous owener.
no bro, i went to 899 for servicing and told them about the wet floorboard. informed by them its the cooling coil need to be change. ( if there is no lost of coldness, the cooling coil is ok)thats to my knowledge. Ask them to check the aircon pipe if there is any choke. but its seems ok. check the door seal also ok. They change the blower cover and the filter and till today no more wet floorboard.There might be any other reason why your floorboard is wet.
