Washer fluid mix ratio
Re: Washer fluid mix ratio
For bmw original coolant, I used 1:1 with distilled water...
juz did that yesterday after seeing the warning, the label did say the concentrate is good for 2.5l of water...but horr i use tap water.. :)
Not coolant...just the wiper washer fluid...I bought a few bottles but the instruction on the label not very clear...it just states different ratios at a different temperature....
each product has diff requirements for diff environment.
it would not be harmful if you dun put screenwash either.
