Hi bro, can PM me the damage and the workshop details. Thanks.
But doing so would give the WS the opportunity to check thoroughly. If not - at least clean the areas where the gasket would sit .........
jinooi;931353 said:
Would have been a huge mistake if they did. The engine looks clean to me.
the brown colour is the colour of the thin coating of engine oil that protects and lubricates the moving parts.
remove that and you might need to run-in the engine again, as you would have to for a brand new car.
jinooi;931354 said:
Next time, pls do not ask them to do engine flush. Your engine looks clean. The flush would have dissolved the protective layer that has formed over the years.
valve seals look ok. So it might not have been the issue.
the 'valve cover gasket' is also called the 'head gasket'. Most likely could've been a leaking head gasket that caused the white smoke.
Did your workshop check the radiator to see whether there was any engine oil in the coolant?
Pls keep us posted on whether after this, you still need to top up engine oil frequently.
Sure, thanks for the advise.
Will take note of my engine oil level
Sure, PM u now
Agreed, very very clean cylinder head!
eddienike;931290 said:
In my opinion, your top engine consider reasonable clean..
to bro DayDreaming, i cannot PM u cos ur mailbox is full.
Hi Bro Aaron, able to PM me the stockist and the cost as well as the workshop and the cost? Many thanks!
Bro, can pm mi again? Thanks.
hi Bro Aaron, I'm keen to know too as my 320 hv similiar issue but not wanting to do top overhaul.
pls pm the cost & contact. thanks for yr kind sharing and
Blessed Christmas!
i also did what Aaron did. But my Flywheel now also leaking :(
Just did a change of ATF and filter to solve the jerking problem when coming to a stop. So far so good but sooner or later need to change the solenoid.....
i got PM u already?
cos i got too many message, abit confused
PM u already
Blessed Christmas!
PM u already
i am also changing my soleniod.
will post it in forum soon
haven yet, can pm mi? thanks..
your car got a lot of problems, will your next car be a bmw again ?
Hi there, pls PM me total cost/ and place where you got the stock and also the workmanship.
with many thanks,
prem
Ha... Good question.
I am looking at the X6 in the near future.
Am still open to all options
Ok, PM u already
