Tyre setup
wt_know
what is the difference between this 2 setups ?
a. front: 235/35/R19 + rear: 265/30/R19 (235/265 combi)
b. front: 225/35/R19 + rear: 255/30/R19 (225/255 combi)
i understand that 235/265 combi is a "common" setup for 19" staggered
i'm thinking to go with setup b because
a. tyre availability -> brand/size
b. cheaper
c. less dragging
what is the side-effect or disadvantage of setup b compare to setup a ?
thanks !
Re: Tyre setup
what's the width on your rims? if 8.5 & 9.5JJ then b setup will be over stretching your 225 & especially 255. dun expect any rim protection from your rubbers with this
btw the savings is only marginal...imo not worth
Re: Tyre setup
front:19x8 & rear:19x9
for better rim protection, i should go with 235/265 combination ?
thanks for the enlightenment.
Re: Tyre setup
Stick to 235/265.
Rim protection depends on sidewall's designs too. Example, given same size, PS2 does not protect lips, but CSC3 does.
Re: Tyre setup
kenntona;425033 said:
Stick to 235/265.
good advise, Ken.
now i know 1 more fact.:woottt:
Re: Tyre setup
Bridgestone tires generally hv good rim protection as well
Re: Tyre setup
just to share based on what i know that most tyres can fit a range of rim width. however they do have exact fit.
you can check against the specs of the tyres you shortlisted.
for 19 x 8 is 225/35 and 19 x 9 is 255/30
for example:
Tire Specs for Goodyear Eagle F1 Asymmetric
Re: Tyre setup
yup. this is the "recommended" tyre setup for the rim that i'm eyeing
for example:
Re: Tyre setup
a little bit of knowledge is dangerous...
pls be 100% sure before you dispense advice...
wt_know;426632 said:
my tyres for 18x8.5 is 255/35 -> i think this is the recommended setup
