Tyre n Rims
KOSMIK
Hi to all the bros here. I am newbie and I would need all ur expertise on this. I would like to change my original 16 inch tyre. My ride to be is a 318iS with vanos.
1) So wat type of RIMS would be compatible n advisable for my ride?
2) Wat type of tyres recommended?
3) Whether the rims recommended would be feasible taking into account for fuel
consumption and performance?
I like the wide rims type ...so wat type of rims(brand) r those?
And any other input advise to be shared?
Thank you..really aprreciate all response.
Mac
Re: ADVICE NEEDED on TYRE n RIMS
Mac
So ur ride is the E36...
1. I'd recommend BBS rims (well they are not the deep dish kinda rims in general but they are damn good)...Get BBS RX or RC. They are strong and quite light.
2. Tires...just like rims, there are many choices
U can choose quiet tires with average handling n performance
U can choose tires that are superb in wet but avg in the dry
or many combinations of those.
U need to ask urself wot is ur priority? Quietness, Ride Comfort, Handling, Performance in wet to name a few?
3. Heavier rims will cause ur acceleration to be slower. U need to press ur throttle more which in turn will end up causing your FC to go up a little bit.
As I suggested, get light rims.
Having said all those,
are u upgrading from 16 to bigger ones or ?
Hi TripleM..Yup..i'm taking into account of upgrading my original 16inch Rims...so..BBS is wat u recommended..
-Nway are the BBS rims wide rims?
-Any wide rims that are light?
As for tyre, I'm looking for average type of tyre for normal everyday use for wet n also dry roads. What do u reckon bro.?
Thanx for ur earlier advise n feedbacks.
Re: Tyre n Rims
Most rims do carry some form of specification e.g. 18 x 8.5J, 17 x 7.5J . The first digit specify the rim diameter in inches i.e. 18 = 18 inches, 17 = 17 inches. The second digit represents the width of the rims i.e. 8.5J = width 8.5 inches.
If you like wide tyres, than go for the 8 or 8.5J specs which meant you need to shod it with 225 or 235 tyres.
BBS got quite a good range for Bimmer 3ers... go to those bigger rims showroom and check things out before committing. BBS is also known for their light weight (advantages as highlighted by TripleM).
If deep dish is what you are looking for, then you need to look into the direction of Hamman.. those rims are really pretty but you may need to roll your fenders (or wheel arches). They are also less common and pretty hard to find.
Tyres are very varied, hence if its just for daily drive, any HPT would be sufficient. My personal preferences are wet tyres (usually comes with bigger block design and deep passages to displace water). Advantage is that they are less prone to "aqua planing" which I felt is crucial in wide tyres application. (Wide tyres have more surface, less ground pressure, therefore more prone to planing and spin in wet weather).
Wet tyres have their disadvantage as they are normally more noisy, especially if you have lowered and stiffen your suspension.
"Wheels" are your only connection to the road and it does command a little more consideration. You will have to weigh and trade "comfort" "economy" "performance" "durability" in your choices..
The easiest approach is to prioritize.. so you need to identify your criteria.
1. How do you normally drive and some consideration of the driving environment.
2. What are the next criteria you are more likely encounter beside the above.
From here, you select a tyres that most suit your item 1 with some veer towards item 2. Happy hunting.
If u are interested, I have a fren selling a set of 17" BBS RXII which he used for a few mths only before he switched to 18". Send me a PM if u are interested. He is looking at $1,200.
