Steering Vibrations Help Needed for F10
z76
Something embarrassing happened few weeks ago. I was turning out left from a car park and before realizing there is actually a kerb on the left, i mounted on top of it; stucked for a while as the kerb was in between my front and rear wheel (my ride is lowered). After accelerated harder, the car moved out from where it was stucked.
Now here is the prob. The car seems to vibrate when steering is turning right, especially slow moving, with some uneven bumps on the road, especially carpark with those rings on the slope. Have checked alignment and undercarriage and all ok. Is there anything which may cause this vibrations or anything else i should check?
Re: Steering Vibrations Help Needed for F10
Did you kill your lower arms? Tie rods? Ball joints?
Hi Meek, was at BVO after that and they did a check, claimed all ok, recommended me to do a alignment which I did but vibs still present. I strongly feel that the left wheel or that area was hit badly as it went up the kerb and came off quite hard.
Are those you mentioned are the things I need to double check again?
I dunno how the check was performed so i wouldnt like to speculate but mounting your car on a kerb like that can cause bad damage. Not sure if your rims are still intact.
Best to get a second opinion if u can.
Rim kiao? Put it on a wheel balancing machine n you will be able confirm it.
maybe the rims dented? did you check the rim as well?
Thanks all, rim is ok as it went up the kerb and came down which made the car stuck.. (front wheel is not sitting on the road)
Reversing the car as the rear wheel still touching the road...
get the tyre shop to check the particular wheel (spin on machine)
sometime WS may not have a machine to spin and check wheel condiotion
thank you all for the comment input... Any recommendations for 2nd opinion is good?
I would say the rim too, get it check at reputable tyre shop :)
:goodup:YES check with any tyreshop can already
why must be reputable shop ?
any shop should able to tell the rim problem ( if they don't know):biggun:
only Good about reputable shop can check and tell you the problem and replace for you the Correct spec rim
Go get it hunter road force balanced ........
33winpro1com
