Sluggy Power in the morning
Westwwood
Hi Bro
Need some advice here. Any of you bros ever encounter when in morning after starting the car and driving off, the first and second gear change seems like no power. 520i is only 11/2 year old. after car warm up, this is not so obvious. No problem until recently. Thanks in advance
Re: Sluggy Power in the morning
Westwwood;1052156 said:
Hi Bro
Maybe time for servicing .....
Hi Bro
i did read before on f10.m5post about this. cant remember exactly what is was, but they said its no biggie.
Hi Bro
I also having this problem with my e60 523, feel like gearbox unwilling to change gear also tends to pull over 4k rpm then change gear. Send few workshop check all tell me valvebody going kaput....
Hi Bro
You going uphill?
Good to state which engine & gearbox... else someone might say his proton cant go uphill and another say his vios uplorry.
1.5 years only...must be same engine and gearbox as you loh...
Assume makes an ass out of u & me.
Thanks for all the advices. Service only recently done and Munich has a new package for engine flush cost @$135. Done that and don't know whether this is the cause for this problem. At first they suspect the thermostat for the cooling fan that is malfunctioning as the second fan tends to on before the engine is too hot. That changed and problem not solved. Still monitoring but still find that the problem exist on in the morning when the engine is cold, Maybe should leave the car overnight at Munich for them to test in the morning.
Don't even need to assume.
If it is really a 1.5 years old 520i, it MUST be n20.
WHY? Let me explain it.
e60 520i was discontinued long long ago...2010 already change to f10 liao, but only 523i, no 4 pot 520i. It was only until later 2011 that 520i came back again, with the n20. There is another 520i f10 with a 1.6L engine, but only for selected market. However, the catch is that this 1.6L 520i was not available till much later, like 2013?
So, unless someone is kum lan enough to use a 90k coe to register a YOM2009 520i in 2012...
Hi mine is a f10 520i 2 litre
Maybe engine retarding timing till it's warmed up.
Ask them to clear the adaptations and see if there is a diff .........
I assume spark plug / air filter changed during servicing ?
I check with them whether is it the sparks plug, they say no. Sparks plug not changed but filter change. When to sparks plug? Mileage 51,000
Suppose to take out and see condition like fouling etc ......
When I first read the title I thought I saw
Shagging power in the morning
But on closer look it's not .......
You must be dating mrs palmer and her 5 dotters too much. Alamak.
