RPM unstable(shaky & jerky)when engine is cold
danny_cha
Hey bros,can anyone advises or give opinions for this problem.
When I started my engine in the morning or whenever is cold,the rpm is idling unstablely and when i started my journey ,its feel like a bit pulling your power and jerky until a while then its back to normal.
Rod did decarbonised and cleaned my trottle boby and even uses the fuel injector cleaner and its ok for about 2 weeks and now is back again.
and today when the engine is hot its happen a while till I gave a hard ram at nuetral gear and is normal again.
Did anyone faced this problem before and hopefully can get some informations for this problem,thanks:( :(
Re: RPM unstable(shaky & jerky)when engine is cold
Now sure what you have e46 - 318 or 320 etc... the 4 cylinder and older models are more prone to this problem. I had experienced this too with my 318... after 3 BMWs I know. A few things... a) the Mass Airflow Sensor needs cleaning or replacement b) Cam shaft sensor? c) Induction Coil? d) Spark Plugs? e) Get PML to set the tuning to a higher idle RPM instead? for some reason your rpm is below the factory setting? f) fuel filter replacement? g) spark cable? something like this order
shd be maf sensor, or exhaust o2 sensors need replacement...
sending wrong signals to ecu resulting in either overly rich or lean mixtures...
Ya mine is E46 318 N42 engine.
I think probably its something related to the fuel issues.
