Rear Right Lower Than Rear Left??
futron.sim
I just measure the ride heigth of my car and found that my rear right side is around half finger lower compared to rear left. Is this ususally due to suspension problem? How can I get it fixed?
Thanks!
Re: Rear Right Lower Than Rear Left??
normal battery is on the right hand rear. has been asked before somewhere....
Yes Battery is on the rear right but it should not cause the right side to lower right?
Car was designed for left hand drive so right side slightly lower than left. If you measure you fronts, you'll notice the same as well. Strange but true.
bimmers are originally designed for LHD - country of origin is LHD. weight distribution between left and right sides are intentionally done for LHD.
for RHD conversions for the RHD world, they had to shift most of the stuff over to the right side, e.g. steering, etc. so right side is now heavier than the left. hence, the right side now sits a bit lower. this is especially evident in the e36 and earlier models.
nothing to worry about...
Dont worry, be happy..
my E46 also same same... unless you go for some coilovers and with adjustbble height, have to live with the strange look :)
Thanks!
its due to the fuel tank and battery which is on the right side.. battery itself is already 30kg.... u go count the weight of the fuel tank + fuel... then u know why.. haha
it will be more apparent if you are running lowering spring though... on stock the car is soo high that you wont be able to tell anyways
there are 2 fuel tanks - one on the right and another on the left, and they are joined in the middle.
at least for the 3 series...
ur ruler got calibrated bo? u ask jinooi lift up his backside for Phil also got different height....
words of wisdom from iscoupe - he knows the best because his right ball is heavier than his left... robot say one...
ya & robot both balls touches the ground while standing.... poor robot. :errrrrrr:
Halow, don't OT people's thread with issues on my balls lah. it's made of steel anyway. And iscoupe has square balls. I bet $15,000 - anyone take?
Sorry for OT. :eek: I think the answer is evident from the replies above, on why our car's right side is lower....
just dont right corner too hard or may topple and become tortoise.
