Rainbow speakers (woofer, Mid + tweeters) plug and Play
Impastokitsch
Dekitted from my e93 with individual audio setup.
Dekitted due to upgrade.
Selling $600 for the whole set.
Interested parties, pls pm and leave me your contact info.
This series of vehicle-specific speaker is equipped with compact and powerful systems. The supplied accessories are designed for the most problematic installation situations. The systems are designed for fitting into factory locations with a good sounding result. Connection and installation are described in detail in the accompanying documentation. So an easy installation of these vehicle-specific systems for experienced grease monkeys is guaranteed.
IL – C8.3 BMW E-Series Front “semi – active”
NOTE: NOT COMPATIBLE WITH E60/ X5(E70)/X6 (E71,E72)
Compatibility:
  • Peak power: 150 Watt
  • Power rating: 100 Watt
  • Minimum amplifier power: 75 Watt
  • Sensitivity: 90 dB 1W/1m
  • Frequency response: 35 - 30.000 Hz
  • Impedance: 4 Ohm
  • Slope: 2 x 12 dB/Okt.
  • Crossover frequency: 180 / 4.500 Hz
  • Tweeter Attenuation: 2x
  • Midrange Attenuation: -
  • Variable Low Pass: -
  • Thermal protection: PTC
Woofer IL-S8F BMW E/F Series
  • Mounting depth w/o / w. ring: 50 mm
  • External Ø with edges: 207 mm
  • External Ø with edges: -
  • Installation Ø: 180 mm
  • Fastening: 228 mm
Midrange IL-MR4F BMW E-Series
  • Mounting depth w/o / w. ring: 36 / 27 mm
  • External Ø with edges: 100 / 138 mm
  • External Ø with edges: 119 / 138 mm
  • Installation Ø: 103 mm
  • Fastening: 138 mm
Tweeter IL-T25 BMW
  • Mounting depth w/o / w. ring: 11 mm
  • External Ø with edges: 44 mm
  • Installation Ø: 44 mm
  • Fastening: -
Fits the following vehicles:
  • BMW 1 Series (Front Speakers) - E81, E82, E87, E88
  • BMW 3 Series (Front Speakers) - E90, E91, E92 E93
  • BMW 6 Series Gran Coupe (Front Speakers) - F06
  • BMW 5 Series (Front Speakers) - F07, F10, F11
  • BMW X3 (Front Speakers) - E83
  • BMW X1 (Front Speakers) - E84
