PSS9 Settings
Re: PSS9 Settings
Terry;222306 said:
the kmac moving?? sounds scary... bahaya ngak?
btw...ada camber plate apa lagi yg bisa muat PSS9 yah
i think it's. anything that is loose in the car isnt good mate.
I hv never seen or heard an after mkt adj camber/castor plate for Non-M PSS9'ed E60 application.
Why u need much camber anyway? Everyone says u drive like a pimp, so slow...
Remove it, save the tires.
Re: PSS9 Settings
w/o the cambre plate.... the tires will rub ... after 2.5 degree of camber.. just nice :)
Re: PSS9 Settings
i juz ordered pss9s...btw due to my front already so low on stock suspensions, can the pss9 set until stock height for front? or die die sure lower?
Re: PSS9 Settings
the highest setting for PSS9 is about as low as eibach lowering spring...about1 finger from fender to tire assuming you are using 245/35
Re: PSS9 Settings
hetraa;222394 said:
icic tks...."keeps fingers crossed"
dont worry...sure look swee swee one... hows the rubbing? any pics of ur car?
Re: PSS9 Settings
keke..my rubbing happens with 4 passengers...havent visit ah lye yet..cos was at man exhaust doing supersprint today..seems quite boomy, expected a raspy note..sounds like sebring..damn.
havent taken pics yet leh :)
Re: PSS9 Settings
RaptureM3;222628 said:
my car has been 2/2 since i installed pss9. is that bad? should i bring it up?
haha alex, i was on 2/2 also..... So far so good....
Re: PSS9 Settings
2/2 is just bout max u should go
If u can take it , then fine...
I only did that setting for track use. For strt, 3/3 lowest for me
Re: PSS9 Settings
Its the workshop pple set for me de.... dunno about it at all until they told me.... i thought its like that de
Re: PSS9 Settings
need a final opinion here, what's the better feature pf PSS9 over KW V2? thank you
seems like everyone is running PSS9
Re: PSS9 Settings
as per Mr. expert's advise... its 5 front 4 rear for me now :) so much more comfy... car dont feel like breaking apart on bumpy roads
Re: PSS9 Settings
Seems like everyone is running PSS9 cuz the thread starter is asking about PSS9 settings. :) For me, I was on KW var.1 on my ex-ride and have ordered KW var.2 for my current ride. Why? Just a personal preference. :)
Re: PSS9 Settings
I like KW's handling better, honestly.
