Overheating
ktnpl
Not sure why the previous thread on overheating was deleted as it contained useful information for fellow drivers so I am starting a new thread to share my experience for the benefit of others who may encounter the overhearting for the first time.
Last Saturday after leaving Vivo City for a short distance, the orange overheating warning ("drive moderately") came on for my E90 LCI 335i and after a few hundred metres it turned to red warning and limp mode ("stop engine"). After start-stop and limping to the nearest surface carpark, I called for BMW Assistance to have it towed to PML Alexandra. The tow truck arrived in about 50 minutes after my call and the repair was done on the 2nd working day.
The water pump, thermostat was replaced on Tuesday. Including coolant, bolts and labour, the bill was $1,660.75.
Luckily most drivers understand my car was in distress mode with the hazard lights on and did not horn at me during the slow crawl to the nearby carpark to avoid blocking traffic.
Advantage of calling BMW Assistance: free towing and includes free replacement of cable under worldwide recall.
After replacing the thermostat, the aircon works better! Previously, the car got very stuffy when it was raining but now the temperature control works fine.
Re: Overheating
water pump failure is legendary for e90 after 80-100k mileage
it is better to replace it before it fails to avoid inconvenience
Re: Overheating
Someone in the previous thread mentioned that he changed the water pump at 50k.
Mine is 45k but the car is over 4 years old (May 2009 registration).
Re: Overheating
my car 5 years 8 months and 88,000km.
how ?
need to replace water pump ?
cannot last till scrap ?
Re: Overheating
almost impossible to last until scrap 10 years
it is better to replace at 1/2 life mark like 4/5 years
else before car end of life then replace a new water pump ... bo hua
my 2009 e90 4.5yrs old 85k mileage also crying to replace water pump
i talk to the mech ... no error code why must change ... waste money
$1k+ for water pump and flush coolant and labour
the mech said, up to me ... yes no error code
if got error code means your car cannot move liao and
if you are 1/2 way on the road ... sibei sian
how ?
Re: Overheating
how you know your car crying for new water pump?
next service at 96,000km I will ask ah wee need to change or not.
Re: Overheating
got warning code for the water pump but can reset the code and continue to run
Re: Overheating
ok cheers.
will pray harder each morning before I start car engine not to see any warning codes.
Re: Overheating
no warning code appear on OBC, no CEL and check ok
the info/warning code can only be seen thru workshop disgnostic tool
just like ktnpl case, if you see code and cel, means call tow truck liao
Darth Vader;1021295 said:
ok cheers.
Re: Overheating
i also replace my water pump ard 100000km at bvo.leaking like shit.so no choice,really hope can last me another 3yrs before car scrape
Re: Overheating
ok cheers.
It will be better to get it repaced as soon as possible. It is definitely inconvenient when the car stalled on the road but it could be worse. Imagine you are halfway up the long ramp at Takashimaya carpark or in the expressway doing 100kph going with the flow when the warning comes on. Then you will only have another 100m or so to bring it to a safe place before it goes into limp mode or stall altogether. In limp mode, the car cannot climb the car park ramp which means it has to be pushed all the way up :0
Re: Overheating
I like ur signature.
Glory glory man united.
Re: Overheating
Previously on E39, water pump bearing seize & breaking rubber belt (together with power steering pump rubber belt). It happens at 6:30am in ECP while i was doing parallel parking.
It break exactly 50k km after my last change.
Re: Overheating
What were you doing so early at ECP and parking at 6.30am?
Throwing used tissue papers ?
Hmmm I wonder ...
Re: Overheating
Hmmm I wonder ...
Early morning jog.... Nice fresh air... *wink*
Re: Overheating
Hmmm I wonder ...
Of course jogging lah. On saturday morning, i need to get home before 8:30am. Part time maid comes after that.
Re: Overheating
To wash up for you....:D
Re: Overheating
Mine kaput when around 5 year mark.....110K Km.
There is no sign, just break while travelling along ECP......limp to fort rd, then turn to small lane, then seek for tow truck. Do not try to start the engine when stalled, over-heating will jammed the engine and the repair will be more than just the electric water pump.
S$800 for the pump + service charge ~ 1K at BVO. Half a day job.
Recommended to change at about 5 years mark.
Hope this help.
