Oil Leak At Temperature Sensor Area
martinkjs
Users Awaiting Email Confirmation
Dear all, what is the reasonable price to pay for that? Did my at ws for $107 after GST and felt cheated as I know the cost of gasket is probably a few dollars only and is a simple job with minimum manhour...
Thanks
Re: Oil Leak At Temperature Sensor Area
Erm.... if the gasket is $10, and takes 30min to change. why didn't you DIY in the first place?
if you own a workshop, how much would you charged?
Thanks
U cant use $$ to gauge whether its worth it anot.... if u rily need it to be rectify and they can solved ur problem... worth it
if ur find that u kena chopped... go elseware...
Thanks
$10 for gasket
$20 for labor
$70 for diagnosing the fault
Lucky did not change the flywheel seal ...... the seal only $2 but WS would charge more than $107.
Roll EYES!!
Problem is during the initial check, ws told me that mine was a small problem and minimum cost. However about 1 hr later, the ws called me and told me that the sensor cannot be taken out and if they use force, they might break the sensor.... So probably they use this 'Hung' method...
Anyway just for sharing.....
I'm confused, so your ws used some more complicated method to remove the sensor and so charged you this high price?
Thanks
I replaced mine before.
Simple job and the O ring cost around $3 only.
Please scan the receipt for us to see
What was the initial expected repair costs? $5? $10?
