NEED HELP WITH F10
_JN
Hi guys I need some help!
anyone have issues like what I have?
i can’t start my car yesterday after I’ve parked n locked it.
called for help to jump start , got it on and running again.
Today I can’t start it again! And I had it jump start with my Honda. But it causes my Honda to malfunction too. End up cant even start my Honda. 3rd solution brought my van over to Jump start but still to no avail. After charging it for 15 mins I finally got it up n running. Drove for 30 mins. Stopped the engine I cannot start again , can’t even lock the vehicle. Can some experts or people with similar experience advise on this?
currently on 523i f10
All wear and tear is replaced for less then a month. So basically everything is new. The spark plug the battery and so on.
pls help!
Starter gonna up-lorry soon?
cheeeeeeeeeeeeeeeeeeeeeeeeeers
Key battery flat?
Ty guys. It’s my battery issue!
Likely the alternator not charging well else it must be the battery cable..
cheeeeeeeeeeeeeeeeeeeeeeeeeeeers
Hopefully not your alternator but sounds like it is. Even if change new battery, can only last till initial stored charge is depleted. If iDrive did not mention low battery, then maybe its cables
Your earlier post says you changed battery not too long ago. Generally batteries last for about 3+ years or more. So its prob NOT a battery issue but something else.
Brand doesn't really matter. Specs are what count. I got mine from thebatteryshop via carousel. He goes your place install for you and codes it to your car. Expect to pay about 400+ for a proper agm battery.
betonstein1
