Misfiring cylinders - due to OWS Iridium plugs?
Clubhead
Re: Misfiring cylinders - due to OWS Iridium plugs?
DC3 said:
Anyone with experience of OWS or other Iridium plugs care to comment?
My mechanic of 6 years used to carry OWS Iridium plugs and stopped because of too many customer complains. Apparently caused a lot of problems with most people. I personally had no experience as I'm always using NGK. I just casually asked him one day since I saw it being sold. This mechanic is a close friend so I would trust what he said. One simple way is to try switching to another brand and see the outcome. If the problem goes away, the answer is clear....
DC3 said:
I am running an M54 YOM 2002 320iA with OWS Iridium plugs installed about 20,000km ago. Other engine mods include Ecotek, grounding and ITG air filter. The car suffered misfiring of cylinders leading to power loss and a "pop..pop" sound with irregular RPMs since yesterday.
When I brought it back to PML, they diagnosed misfiring of cylinders 1& 4. Of course they blamed the OWS plugs and the ignition coil was also faulty. Fortunately, the coil will be replaced under warranty but I seriously doubt that the plugs could cause such a fault. Should I have chaged the Iridiums earlier? Anyone with experience of OWS or other Iridium plugs care to comment?
There're some batches of the 1st generation OWS iridium that are giving such problem.......
So go back to where you got the 1st generation OWS & they'll gladly exchange them for the latest 2nd generation iridiums.
Hope this helps......
Cheers!!
'The Great White'
Cheers!!
'The Great White'
Thanks Wilson.
Had them installed at BVO when I bought ITG from you. Will check with Bernard or Ah Wee.
Cheers!!
'The Great White'
Thanks Wilson.
Oh!! Hi bro!! How R U man??
Just dropby to BVO & complain that your 1st generation OWS plugs got problem & they'll give you the 2nd generation FOC!!! Remember to ask Ah Wee to gap the new plugs at 0.8mm yah!!
Cheers!! :thumbsup:
'The Great White'
I used to have this problem when I was driving the Legacy. I used the Platinum plugs and when I switch back to copper plugs I had problems idling as well as misfiring.
Took to my mechanic and he check...one of the ignition cables were faulty and he replace it and all was well.
Cheers!! :thumbsup:
'The Great White'
Thanks Wilson.
PML changed my ignition coil FOC, but charged me for 6 pcs NGK high power plugs at $20 ea with labour charges of $75... ouch!!! These stock plugs are supposed to have a warranty of 2 years but the engine seems more sluggish, less punch. No complaint about standard of service at Kampong Arang though.... far cry from Alexandra!
Cheers!!
'The Great White'
Thanks Wilson.
Cheers!! :thumbsup:
'The Great White'
Hey Bro...I think I know you who liao lah....are you the one who always wears a blue cap...Sony Ericsson T610 with BT headset one ?? Remember you BT me the Sony Ericsson screen saver of a tacho meter going up and down one ??
Cheers!! :thumbsup:
'The Great White'
Thanks Wilson.
aiyo $20 for a stock plug dam ex man!!!! $75 for changing plugs lagi ex man!!!!!!
but u still can go back to bvo with the old ows plugs & get the 2nd gen plugs installed, foc somemore!! den keep the stock NGK plugs in the trunk loh!!
Cheers!!
'The Great White'
Yup, that's me!! Aiyo, must C U again den can match your nick to you lah!! Nxt time C me at BVO just buy me kopi & say U're the 'Ghost' ok?? :laughlik:
Cheers!!
'The Great White'
