M3 engine in Non M3 Coupe
jaskin
Legendary 10 Years
Just wondering, as a matter of interest, would a M3 engine fit inside a non M3? Any idea what retrofits need to be made in order for the M3 engine to be accomodated.
Jason
Re: M3 engine in Non M3 Coupe
jaskin said:
Jason
can fit... infact the s54 engine has been put into a station wagon before...
actually even the e39 M5 engine can fit if you make the proper mods to the chasis, but its gonna be a big job as you prob need to relocate all the engine mounts, tranny mounts, maybe move the firewall among other things.
So would the S54 engine be a relatively simple install?
Not sure if it's simple but I m pretty sure experienced/established work shop familiar with BMW engine can do it well.
In addition to wot MRacer has said, S54 engine can be put in either Z3 or Z4 too hence the MCoupe model..
There had also been cases where the E36 M3 engine ( think called S52) had been retrofited into some E36 sedan/coupe. :whatthe:
Dropping in the engine is very easy, the hard part is getting it to run with your car. Shafts needs to be changed, differentials, gearbox, ECU, harness, dashboard, etc.... Very tough but possible job if you ask me... The labour would probably cost you an arm and a leg too...
So, how many moolahs we toking about? In S$. My arm n leg very ex wan wor..
So it's a huge upgrade. Take a look at this guy in the US
http://forum.e46fanatics.com/showthread.php?t=176943
Own Time Own Target DIY 323 to M3 conversion.
Looks like alot of work. Th good thing is that there an M3 engine on sale at the moment for US$8K with 15K miles. It'll probably be more worth while than Super charging etc.
this guy is superman..he is the king....i m not worthy.
Ya man...50+ pages...see until blur..some more he take so many pictures then post 1 by 1...sweat blood man this post...u guys should check it out..
this guy is the man... he is now my idol... where is his shrine?
it is a s**t lot of work man... but it can be done, best by a professional.
He is George Lee from San Marino (North of Los Angeles). Will be dropping by his place sometime this month. Will try to extract more info/knowledge from him and perhaps "maybe" even snap some 'latest' overall pics and share it here....however, will respect his privacy if he so wishes.
Tell him we're in awe at his DIY prowress. He's going to S/C the M3 motor too right?
