The Mixmaster
Apart from comfort, another factor to consider is the higher costs of tyres for 19" rims.
For 19" tyres, the choices are also more limited.
jaskin said:Hi TOby,
Thanks for the reply. I was wondering would installing the Sachs kit void the PML warranty in anyway?
Racebred said:if you bua the fenders without lowering your ride, something is wrong. a solution will be to roll your fenders. what's your rim offset?
generally its hard to find aftermarket ready-to-fit-e46 suspension upgrades that doesnt lower the car. the only solution is to go for height adjustable coilovers, but they easily cost double the price.
your coupe suspension is already supposed to be harder than sedan
kenntona said:OT a bit, but is it true that the weight distribution of our bimmers tips the car more to the right? Between my chassis and the REAR wheels, the driver side has a narrower gap than the left side's one-finger gap. Difference is small, but still noticeable if you slot your index finger into the gap.
Hope it is not my weight that put too much strain on the Sachs.
DVanos said:my e46 coupe is running on 19" as well, changed to k2 v2 coilover some years back, its height adjustable, so far no prob.
btw, wat kit u hv on your coupe?
Charontes said:DVanos said:my e46 coupe is running on 19" as well, changed to k2 v2 coilover some years back, its height adjustable, so far no prob.
Hamann add-on kit..
this one..
