Key low batt
HotCooler
Hi is there anyway to change batt for 3 series non comfort access key? It's low batt now, or just insert it into the ignition until the low batt indicator is gone?
Re: Key low batt
If I'm not mistaken, when you insert the key into the ignition, it will charge up the battery since its a rechargable battery.
Re: Key low batt
Don't think fob battery is rechargeable, need to replace if weak. But can still start car if battery weak...see this...2014 New Key Fob Coding (w/ Comfort Access)
