Introducing the new 3 series coupe (2006)
Re: Introducing the new 3 series coupe (2006)
New BMW 3-Series Coupe Revealed
Twin-turbo technology for 3 Series
Heralding the dawn of a new era in engine technology, BMW’s all new 3 Series Coupé range goes on sale in the UK on 23 September 2006. The third generation of compact coupé marks the introduction of the first ever twin-turbo petrol-powered engine in a production BMW as well as pioneering Direct Injection technology. Two models will be available at launch.
Designed for sporting elegance
Despite its close technical ties with the 3 Series Saloon and Touring variants, designers set out with the goal of differentiating the two-door model more than its predecessors. From the front, side and rear, the car is clearly related to other 3 Series models but has its own, classically elongated, shape. Adopting BMW’s typical Coupé proportions of long wheelbase, short overhangs, long bonnet, cabin set to the rear and a low, sleek roofline, the new 3 Series Coupé has an elegant profile.
Key highlights in exterior design are the kidney grilles and restyled headlamps that give a bold yet elegant frontal view. At the rear, the broad rear lights use horizontal light rods with bright LED illumination to accentuate the low, wide appearance of the rear of the car.
Another change from the other models in the 3 Series range is the use of lightweight materials in the body construction in the Coupé. While all 3 Series models use Tailored Blanks that increase panel thickness where structural rigidity is needed, and reduces thickness where it’s not, the Coupé variant also uses plastics in construction. As a result of the lightweight plastic front wings used on the 3 Series Coupé the new car is an average 10kgs lighter than the Saloon variant.
Twin-turbo in-line six-cylinder
The all-new Coupé bodyshell clothes the twin-turbo 3.0-litre engine in the new BMW 335i SE that develops 306hp and 400Nm of torque between 1,300 - 5,000rpm. With such performance statistics, the 335i forms the pinnacle of the new 3 Series range.
The 335i SE Coupé accelerates from zero to 62mph in 5.5 seconds, and, if left unchecked, would travel on to an electronically-limited top speed of 155mph. This level of performance is made possible by two turbochargers, each supplying compressed air to three cylinders each. The use of two smaller units ensures that the turbochargers react more quickly to changes in the throttle position all the way to the 7,000rpm red line while also eliminating the previous scourge of turbocharged engines – ‘turbo lag’.
The turbocharged engine is also considerably lighter than a normally aspirated powerplant of equal power. In the case of the 335i, the new twin-turbo six-cylinder engine weighs approximately 70kgs less than an eight-cylinder engine of corresponding performance. This weight advantage benefits both fuel economy and weight distribution.
BMW’s all new high-precision Direct Injection system also aids these high levels of performance while also benefiting economy. Piezo injectors, located centrally in the combustion chamber between the inlet and exhaust valves, deliver atomised fuel in a conical burst into the chamber to ensure a smooth, efficient burn.
Piezo crystal injectors work when an electrical current is passed through the crystal to create a very precise and consistent fuel delivery. The result? Only the exact volume of fuel required is delivered into the combustion chamber on each cycle guaranteeing that all the vapourised mixture is burnt. This method of injection also serves to aid combustion chamber cooling, thus offering a higher compression ratio. As a consequence, the new car delivers an average fuel consumption of 29.7mpg on the combined cycle.
Entry-level six-cylinder
At the launch in September, the new 325i SE Coupé will form the entry point to the range. Delivering 218hp and 250Nm of torque from its 2.5-litre in-line six-cylinder engine, zero to 62mph is achieved in 6.9 seconds and the top speed is 153mph. However, performance does not compromise economy with the 325i SE Coupé delivering 33.6mpg on the combined cycle. This is made possible thanks to BMW’s patented VALVETRONIC variable induction technology and VANOS variable valve timing that, when combined, balance the requirements of performance and economy.
This level of economy is also made possible as a result of a number of weight and power saving measures in the engine. The 325i Coupé is the latest BMW to benefit from the magnesium – aluminium composite cylinder block first seen on the BMW 630i in Spring 2004. The lightweight combination of materials reduces the overall mass of the car and helps achieve the near-perfect 50:50 front-to-rear weight distribution for improved handling.
Finally, the 2.5-litre engine uses an electrically-powered water pump. This not only eliminates the engine power normally needed to drive a conventional crankshaft driven unit but also reduces the engine heat-up time to improve engine efficiency and occupant comfort.
Gearbox options
All new BMW 3 Series Coupé models come with a close ratio six-speed manual gearbox as standard. Those drivers who prefer the convenience of an automatic transmission, but the driver involvement of a manual, should opt for BMW’s new automatic gearbox option. Using an innovative torque converter and software set up, the new automatic gearbox offers a 40 per cent improvement in the response time to throttle inputs and a gear-shift time nearly half that of a conventional automatic transmission. Whenever a driver wants to take control of gear changes a pair of selection paddles located behind the steering wheel can be used to change gears.
Practical and ergonomic interior
Internally, all controls fall easily and ergonomically to hand. The seatbelt is now also delivered to the driver courtesy of a feeder arm integrated into the B-pillar. This only operates on the passenger side when the airbag’s seat detector recognises an occupant.
Both driver and passenger in the 3 Series Coupé sit comparatively lower in the car than they do in its Saloon counterpart. This ensures the maximum headroom for occupants, even with the lower roofline of the Coupé, and also gives occupants a safe, cosseted feeling in the car. Practicality is also a priority with the new 3 Series Coupé offering up to 440 litres of boot space in conjunction with convenient storage solutions in the interior.
Chassis and body – a sound basis
In common with all BMW models, the new 3 Series Coupé benefits from a near-perfect 50:50 front to rear weight distribution and rear-wheel-drive for the optimum in driving dynamics. A double-joint tie bar front axle with spring struts made almost entirely from aluminium and a five-link rear axle work in combination with a rigid body structure to provide very high levels of stability and comfort.
The 3 Series Coupé also comes as standard with Dynamic Stability Control +, BMW’s latest traction control system. With DSC+, the highest levels of traction and stability are complemented by the latest comfort and safety systems including brake pads that are dried in wet weather conditions and brakes that are applied harder when any possible brake fade is detected. This ensures the car remains under maximum control at all times.
To enhance the chassis and suspension set up, the 3 Series Coupé comes with a rack and pinion steering system as standard. Customers can also opt for BMW’s innovative Active Steering system that varies the steering ratio as a proportion of road speed. The Active Steering system additionally links into the DSC+ system, adding small amounts of steering correction without driver input when oversteer is detected.
Extensive safety systems
All of the passive safety systems of the new Coupé are controlled by a restraint and support system. The six standard air bags, seatbelt pre-tensioners and belt force limiters are all activated by the type and severity of a collision.
Recognising that the majority of accidents occur in the dark, the new 3 Series Coupé comes with Xenon headlights as standard. Customers wanting to improve visibility yet further can specify BMW’s Adaptive Headlights that, using the steering angle, aim in the direction the car is travelling rather than the direction it is pointing.
Drivers following a 3 Series Coupé might also notice BMW’s Brake Force Display at work. When the driver of the Coupé needs to execute an emergency stop, or when the ABS system is in operation, the driver behind is warned of the danger ahead by an additional illumination of the LED brake lights in the lamp cluster.
Future Coupé models
Other engine derivatives start production in September to broaden the 3 Series Coupé range. The new BMW 330i Coupé will develop 272hp from its normally-aspirated 3.0-litre six cylinder engine that, like the smaller engined 325i Coupé, uses magnesium alloy in its engine construction. Acceleration to 62mph is dispatched from standstill in 6.1 seconds with an electronically limited top speed of 155mph. The 330i Coupé still delivers 32.1mpg on the combined cycle.
At the same time as the 330i, the new BMW 330d Coupé will start production, offering 231hp and 500Nm of torque. Performance and economy are both top priorities for the diesel-powered Coupé, with the car posting a zero to 62mph time of 6.6 seconds while still delivering 43.5mpg on the combined cycle.
Details of the future entry-point BMW 320i and 320d Coupé models will be announced at a later date.
seriously, this looks nice
so i'll reserve judgement on the design till i see it in real life
This is nice man. It's has the "Wow Factor" the first time I look at the picture :)
the coupe look abit like a luxury car
i think BMW lost its fetish for tight asses. the ass looks too flat. and blunt. front looks like a revised e46. very subtle design nonetheless elegant and graceful. However, if the new m3 is based upon this, its gonna be a bad idea. i hope atleast the e90 platform would be chosen. it has alot more potential for an aggresive look. this e92, i have yet to see kits that can transform this into a beast. nontheless, its still early.
WOw.... nice car..........
I like it..
Time to look for buyer for my Evo9 liao!!!
ok, I will be 85k bid for your Evo when the coupe arrives here hahahahaha.......
I like it..
waa.u serious arh?ur car looks so chio..if u want that new E90...get it..without selling ur car..so u hav 2 cars..:) but i think this sports 1 dun look better then the E90 M3! i saw a pic of it b4..the rims are huge!
Swee!!!
Hmmm.. if launch in UK this sept, will reach singapore early 07?
My Evo 1 year old only leh... can bid higher a bit??
hahaha..
does the new 3 series coupe have space for spare tyre? one of the reasons i do not like about e90......
u never know what is going to happen if shit strucks u while travelling to kelantan......if u know what i mean.....
best combination should be rft with space for spare tyre. eg: like e60......
if it is based on the e90's design and comes with RFT, i do not think they will a space for spare.
the most irritating thing is when you want to change to 18' or 19' non-RFT, you will have trouble travelling up north. let see how it goes...
Could you elaborate why one would have more trouble travelling up norh on 18/19 non-RFT?
Thanks!
hmz......would the Air man pump be an option???
anyone has experience with it??
there was a thread someime back, but it's thus far non-conclusive...
SM----short of squeezing a spare tyre in your boot, travelling up north on upgraded non run flats can land you in trouble should you get a tyre puncture.....since i highly doubt BMW road-side assist is an option there....
now i wonder.. will the new twin turbo 3 liter engine will find its way into the 5 or 6 series? that would be nice! a 535i or 635i?
I agree with u, the rear looks really un-BMW like. Looks too soft and v japanese. However, the front and side view looks gd~
SMYUEN said:
Thanks!
cause no spare in the boot
and there is no space for a spare. hopefully they add the space for a spare. they remove the spare tyre space but then did not do anything with the extra space
these pics of the car look pretty good...dream...
i think it should be ok (i hope so) if u travelling up north during the day. at least, if something happens to your rft, u could find a shop during the day to replace the tire. yeah, they claim, without air, u can travel for (some say 500km, some say 200+km, n some say 100+KM) at a speed of 80km/h. that's theory but anything can happen in real life. bmw also claims theoretically u should change the engine oil every 25,000km but i doubt many bmw owners do that. theory is theory, real life situation is a bit different.
but also a problem if u travelling at village areas where there's no where tire shop to find. anyway, worst still, if u are travelling at night, say 12am......... all shops are closed. u just don't have the sense of security driving e90, knowing that if shit happens to your rft. there are many ways to save weight but why getting rid of space for spare tire? at least if u don't want to put the full size spare tire, put the little ones should be ok.
lots of people in australia complaining about lack of spare tire in e90 coz driving interstate in australia covers thousands of km. but then i guess, 99% of e90 owners would spend most of their time in the big cities.
air man pump? sometimes it works, sometimes it does not. but spare tire......always works.....
again, the best is still rft with spare tire like e60.
in terms of shape, the new 3 series coupe looks beautiful to me...........
