Insights into ECU Tuning
davidtch
Legendary 10 Years
[video=youtube_share;_I8SAT-u2-I]http://youtu.be/_I8SAT-u2-I[/video]
Re: Insights into ECU Tuning
..... my ecu took 30mins to download and external battery stabiliser was used too :(
For the dyno run, is it just pull in one gear across the rev range ?
Not pulling in few gears like normal driving right ?
Just my 2 cents. A lot of tuners don't give you a dyno. I've done it before -- it's a waste of time. IF there's no dyno, don't buy the tune.
Ya, that tuner will ask you pump 98 before tuning and drive aggressively after tune to let the ecu adapt blah blah blah
After which we really get a more responsive car but its not because of the tune .....
EXACTLY. What I found out was that the throttle response changed, but the engine is still pulling the same. I think if you get a proper computer tool and do an ECU reset you will get the same results.
Sounds like something that should have been done at the end of a servicing .....
Sorry for a noobie question on tuning.
Powerbox will be more easier solution and safe compare to ecu reflash?
Depends on who sold you, the installer and the tuner.
I am just waiting someone selling 2nd hand BMS powerbox because alot good review and it was on local market for many years and reliability proven.
Xiaochew;1094779 said:
Hi guys. Newbies here. It's there any tuning solution for f10 523?
Pls share tks
Look around site sponsor lah.
For NA, the best tuner is your foot. Drive it like you steal it for a few days.
