iDrive kuku
horrible
My iDrive went kuku today.
Anyway I can reset or must go back pml?
kinda like hang. Vol control seems retarded.
vol goes up n down.
Re: iDrive kuku
My car barely a year old.
too early for a change.
wonder if tis is common here.
from my earlier link, seems like a frequent occurrence.
Gonna try it.
hope its just as simple as pressing and holding both cd eject+vol button for 30s
Re: iDrive kuku
Above doesnt work.
On the older CCC like in early E90 it was "Eject+Power button" to reset
Gonna try tis later:
On the newer CIC ( like F10, E90 LCI and F30) its "Hold down the Volume(power) button for 25 Seconds" to reset the system
Re: iDrive kuku
15 second will restart the CIC. But it is only restart, which is done automatically every morning you turn on your ride.
Re: iDrive kuku
Yup.
reset doesn't work.
worked fine for a while then its back.
the audio control knob just seem to hang, only can work using the steering vol control. Other functions work normally.
max,
Do u have a solution?
I dony want to waste my time at e agent.
Re: iDrive kuku
All buttons on that panel not working now.
Nothing done to the 1,2,3
Only mod done was the addition of an aftermkt rev cam 1.5yrs ago.
That's still working fine.
Re: iDrive kuku
No worry, if you are free, drop by to have a check. Should be a small issue.
Re: iDrive kuku
Tks Max.
I tried updating the idrive. That didn't work. Only worked after I reset it again the next day. No issue ever since.
