How to hook up Boost Meter to a SC?
danielO
want to hook up a Boost Meter to my SC.
dun ask me why la... just for fun la.....also can monitor if my system is leaking!
Re: How to hook up Boost Meter to a SC?
Look for a port that connects to the manifold just after the SC. There should be 1 which runs to the fuel pressure regulator (if you have one) or from the brake booster vacuum line. If you are taking from the brake booster line, you will need an adapter to tap off the small hose and make sure it is tapped off closer to the engine side so that you do not miss the vacuum check valve inside the brake vacuum line.
