How do you find BMW's SatNav ?
  • BMW SatNav
    Votes: 0 0.0%
  • Aftermarket GPS
    Votes: 0 0.0%
  • Total voters
    0
Ahbengdriver
Legendary 10 Years
Car owners with BMW SatNav and 'aftermarket' GPS (eg Garmin Nuvi). of cos we all know the map is very important.
which one better?
Re: How do you find BMW's SatNav ?
BMW SatNav works fine for me. Neat and integrated and no worries with wires hanging around or weird-looking suction caps on the windscreen.
Like what ACS6 said, its nice and well integrated but its a pain to use... typing out street names takes a long time... but its definitely a nice feature! I got where i wanted to go with no problems.
Clean and good mix with the car. Again, not having aftermarket parts is a plus point.
Problem is my navigation volume is the same no matter whether i set it to softer or louder (must be recent flash).
However if Garmin came in the same interior colors or is perfectly matched..................hmmmmm
As the voice speaks, try turning up or down the volume button and see if the voice does the same too?
After using various variants of the VDO Siemens /Harman group Satnav (OEM), and also Garmin aftermarket, my comments are:
The maps on the OEM are sufficient, but not stellar in detail.
The OEM satnav refresh is very long cycle, and certain changes in roads in Malaysia, and to a lesser extent, Singapore, not reflected. Will cause severe issues in KL at least.
Some OEM systems are integrated with a gyro system which, in the absence of a satellite signal, will track manually the movement of your car together with ECU sensor data for quite a long time (5km?) with a good degree of accuracy, in order to make sure you don't get the dreaded `lost satellite reception' and LOCKUP issue you get with most aftermarket system without gyros.
The Garmin 276C and Nuvi 6XX series can use free maps, legally, from GPS Maps of Malaysia & Singapore
The malsingmap maps are stellar in detail and has routing
They are updated very regularly and almost everything is there, including points of interest for bak kut teh etc. EVERYTHING!
If you go to Australia, USA., UK, etc. you can get free maps too, just take your NUVI / 276C along and you're in business immediately. I travel and drive a lot, and these are invaluable.
ALL IN ALL, i will forgo the OEM GPS and spend a thousand bucks or less on an aftermarket Garmin 660 or Garmin 276C (for tracking and contribution to Malsingmaps).
Yeah bro, it's hell much smarter than my N95...lol...ended up driving my own way every single time I try to rely on the phone for directions.
I know, don't ask me why....BMW SatNav...and N95....why need both? I dunno.
hey which one are u using on the N95? Agis NavFone or the Nokia Maps? for a phone gps its quite commendable...heh
I find the NavSat's response too slow... by the time it tells me to turn, I am at/going pass the point of turning.... :furious:
