Hi. I am no expert here, just sharing my own exp.
My screeching noise comes only when i light brake, usually means you are braking from a slow speed (eg. parking, or slowing down to a traffic light). My screeching is only from rears since they are not braking as hard as the front i suppose. Hard braking (usually from high speeds)almost never hear any screeching.
If your answer to above is yes. than follow Jin's brake bedding link. I did that and it was better but did not totally eradicate as my pads are not stock (higher performance types) but my rotors are. so they may not be perfectly compatible to begin with.
sometimes we think the screech noise only happen after you changed something, but it could be there all the while but we never noticed (maybe windows were down lately after your last change that you noticed and start getting more aware).
If above don't work than go another w/s to inspect for piece of mind.
PS:
I did tried WD40 out of desperation earlier on (my low speed braking screech was so bad that everyone thought a taxi is coming their way and they were going to wave me down, so mah lu!), it did got rid of the screeches but only for a day (the braking power was still close to normal actually
). Dun do that and dun tell Jin i did it :shhhh:
