Help! my roof is leaking. need contractor recommendation
vd383
the recent storms have shown the weakness of my roof.
i'm staying in a inter-terrace
anyone has engaged a roof leakage repair company before & like to recommend their Good service
I used 1 company before. not very good. came like 4 times in 1 year. they say sometimes the repair is more ART than Science. after patching 1 place, the water will find new place to seep thru.
Also, anyone has advice to give about this roof repair?
Re: Help! my roof is leaking. need contractor recommendation
the photos show the current 'water-prevention' set-up.
what did the contractor do to repair yr roof? just did a cement screed to the corners? did they replace the metal roof flashings?
where did the water seep though? only at the corners/sides?
The photos show work done 4 yrs ago when roof was constructed
Leaking thru the sides where the joint is with the side wall
from the pics i can only deduce that the metal flashings were inadequate . it shd be covering the entire fire stop wall
Thanks. i think so too. my wife says it's called CAPPING
i think right wall can cap, cos quite low.
but the left wall how?
this is my neighbour's setup next to my my adjoining wall which is higher than his roof
I have a close friend whom specialise in this trade, have PM you his details.
frm the new picture....i can see that the capping/flashings are alrite leh. yr water seepage is water marks on ceiling ? most prob is neighbour wall's cracks/holes
The new pic is my neighbour's roof, not mine
water literally dripping from the joint between false ceiling and wall - which is directly below where the flashing is
Answer: Your roof needs inspection to determine the cause of water penetration. Roof repair is a job which requires experience to identify the root cause and fix it before you make any repairs.
Also, anyone has advice to give about this best roofing company in northern va?
I had my roof replaced in 2020. We just had a heavy rainfall over the past week and my tenant notified me that their is water leaking through the ceiling into their laundry room. I checked the attic and and there is water damage from a 2 year old roof! There is no external damage i.e. tree falling down etc...
Who do I get involved to get the roof repaired? The original contractor who installed the roof? Or someone else to address the issue asap? I was also told at the time of installation that the shingles have a life time warranty, not sure how that comes into play here. Additionally, can I hold the roof installer responsible for the water damage? Has anyone ran into the same issue? Appreciate any insight.
Thanks -
You may contact few of the below contractors. They did well for me and in my circle.
The price is quite good too. The staffs are respective too.
High tech roofing & waterproofing company
Gaushan construction Roof waterproofing contractors
To find a reliable roof repair service, seek recommendations, check online reviews, and verify credentials. Get multiple quotes, inquire about warranties, and ensure clear communication. Prioritize companies with detailed contracts. Address the root cause of leaks rather than temporary fixes. A thorough inspection is important. Quality repairs now prevent future problems.
For an inter-terrace, I’d get a proper inspection rather than continuing with repeated patch repairs. Water can travel along the roof structure before appearing at the visible leak, so fixing the spot where you see water doesn’t always address the actual entry point. I was also looking at a polaris ranger roof for another project, which reminded me that the right materials and proper sealing matter for preventing leaks. I’d look for a roofing contractor who can inspect the tiles, flashing, valleys, ridge, gutters, and roof-to-wall joints and provide a written assessment.
