s555555555
Yo! Newbie here. Wanted to say hi to everyone. Got a used E92 335 since abt 3 months back
S
S
s555555555;1013887 said:Yo! Newbie here. Wanted to say hi to everyone. Got a used E92 335 since abt 3 months back
S
seanskye;1013890 said:Nice ride. Welcome aboard!
ac323;1013888 said:Hi S555555555,
welcome onboard...
* Previous ride S5?
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
s555555555;1013976 said:Hi Bros, would like to seek some advice.
I installed jb4 about 1.5 mths back. Nine out of ten times this happens since installation.
When driving hard, after 5-10 mins, the car jerks and looses power, RPM drops to about 1.5 so i let go of the gas. When i accelerate again gently, once past RPM abt 1.5 the jerking comes back. the more i step, the more violent the jerks. When this happens i just crawl to a safe spot, off engine and restart and all is back to normal. Quite scary. Now i am just driving on map zero which essentially means on stock ecu, jb "switched off".
car has:
-pml installed performance exhaust
-dual cone air filter
-using either map 1 or 5 on the jb (recommended by ws)
to make things more tricky, once on the jb map, it hijacks the ECU and so no warning lights come up. So when i took it to the ws, the computer diagnosis does not detect any faults and they say it seems to drive normal. Does anyone have any experience or advice to share? Could you point me to something so i can maybe do more research?
thank you!
S
s555555555;1014155 said:Thanks JJ. And Tatler, thanks for sharing your experience...much appreciated. I will go check those parts you mentioned. Actually i did ask workshops if its any typical problem parts that is the cause and after the computer diagnosis turned up clean, and they test drive, they told me: Bo tai ji leh...
Will update once I sort it out.
In the mean time any others who can share some pointers pls do.
S
actually if i am not wrong, JB4 do not hijack the errors thrown by the ECU.. i.e. you will still see everything...s555555555;1014155 said:Thanks JJ. And Tatler, thanks for sharing your experience...much appreciated. I will go check those parts you mentioned. Actually i did ask workshops if its any typical problem parts that is the cause and after the computer diagnosis turned up clean, and they test drive, they told me: Bo tai ji leh...
S
tatler;1014156 said:If bo tai ji then i suspect jb4? Maybe mine too? The jb4 causes that?
