Greetings from Newbie with 523i
DJ Z
New Member
Hi all,
Good to know there's a place to share and discuss with the beemers. Bought a 6yrs old used 523i recently, first few weeks are going all fine, but noticed a few small problems.
When startup the aircon will have some gas leaking kind of light noise, and remains there. Later on I realised the coolant got empty every 1 month plus or so (filled up premixed coolant 2 times alrdy). Is something wrong with the aircon system?
Also noticed that if I start up the engine in the morning, the RPM will bounce between 1-1.5k for a few times with some noise for about 30sec, then settle at the normal idle 0.8k level. If release the brake and go to D drive the car during this grumpy moment the car will sprint a bit with the bouncing RPM which is a bit scary. Warm up the engine can avoid this problem, or if the car runs for a while and stop engine, restart also no such problem. Is this normal and just need to warm up the engine properly, or I should go to service shop to check the gearbox and engine??
Thanks and hope to have some help and advice from experienced buddies here.
Merry Christmas to all!
Hi all,
Hi DJ,
welcome onboard..........
*** send to a workshop sounded like a good idea...
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
