Gearbox problem of 2007 E90??
rayyang81
Hi all, I have gotten a 2007 2nd hand E90 about 1.5 months back and recently I noticed that there is a slight sudden jerk during the 1st and 2nd gear change. Subsequent gear change is smooth without jerk.
Is this normal or is there something wrong with the gear box?
Re: Gearbox problem of 2007 E90??
This is normal, but if you are able to get someone to reset the gearbox then the jerk would be eliminated. The jerk would usually come back awhile after the reset though.
Not normal. Look for Rodney..
I have a 07 320i ,having same jerking problem,stop with drive gear engage there will be a sudden jerk...and also jerk or slip during acceleration between 2nd to 3rd gear,,
Is it a transmission problem.?
Mine happens only when starting off..like a manual car changing gear... not smooth until 3rd gear onwards. Any experts can advise what the problem is?
Who is Rodney????
Hi ray,
it will be better to sent to a workshop for a check......................
* prevention is better than cure....................
ac323;824809 said:
Hi ray,
Any workshop to recommend???I milkbie....... :nutkick:
there are quite a few workshops ( under site sponsor ), all should be good to go...
* still got MA
cheeeeeeeeeeeers
Thanks.... U are very helpful..... :thumbsup:
No problem...............
will try to help abit since C3PO is not around.........
* not sure will he be trained to be a mechanic inside........hearsay they do learn some skill inside.......
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
C3PO...... Busy mopping floor and doing gardening...... :helpp!:
eddienike;824894 said:
Milky milky... Is our site sponsor Rodney from R2D..
Oh..... Thanks...:thumbsup:
if you're feeling a tug when car is stationary then means up lorry liao
got my ATF changed and gearbox software reset recent. jerks are gone now. :thumbsup:
Do u mean that at stationary while the car is iding then the rpm went up & down? Not consistent?
no it's when u feel a tug like someone shoving you from behind, nothing to do with the engine
hmmmmmmmmmmmmmmmmmmm............................:sneaky:
Staff online
