F10 steering kok kok sound
Re: F10 steering kok kok sound
Jason8822;1017833 said:
Rabid,
not wheel bearing, SUSPENSION MOUNT BEARING
once upon a time i changed to KW Street Comfort and drive a lot on bad road
then finally kok kok kok sound came
ws change for me to M3 bearing (sibeh sart ?) but 6 mths later also kok kok kok and change to dunno whatever bearing
yes jason, susp mount bearings. i had the exact same prob when i changed to eibach sportsline springs for one of my prev cars. very sart and very low but very kok kok kok and irritating too.
Jason8822;1017834 said:
if this case, then most means the mounting nut loose which is very unlikely case
It could be there is very little gap btw mounting & strut top.
The same problem exists in all F10 in MY since it's intro. It has never been resolved till now.
why is it more prominent to F10 in MY? is it due to the bad road condition?
I don't know. But bad road condition is 1 of the reason. Check out F10 section of BMW Club Malaysia.
My f10 got knocking sound from front left wheel at full lock to the right, steering wheel will also vibrate badly...sounds a bit like a bad drive shaft joint, but front wheel is not driven...
Sounds bad. So fast?
What size front tires you guys riding on ?
Maybe tire BUA the plastic inside fender ?
My replica Breyton warp and part of the tire rub against suspension - the part where spring sit on and the tire was gone in 3 days, luckily i happen to take out wheel and was shocked to find out.
Otherwise i will only get a burst tire and skid on the road.
i find the loose pedal sound is more anoying than the steering kok kok sound
loose pedal sound - when you release the brake and step accelerator there is this very soft kok kok sound
Haha me too, i tot my brake pad is not seated in the caliper properly or some parts worn off
Pedal still nt so jia lat. My seat lagi worse. Leather bua leather. Pml told me buy their leather care n wilsolve issue. Knn . It got worse
If you know which part bua then do you mind sticking velvet on either part to alleviate the problem
Ah yang;1018822 said:
U dun drive so hardcore ok. Jaxontoh nt here no nid race
Ok, wait he appear then ... JASON vs JAXON
