F10 steering kok kok sound
steve9733
Hi all brothers,
My F10 around one year, when steering there is a slight kok kok
sound.. It is very soft, very soft, and only happens
sometimes..
Like when i steer 60-80 deg to right or left, then there is maybe
slight sound kok kok 2 times..
Can anyone who has the same problem enlighten me ?
As when i sent to workshop, they only try lubricate the
steering column, steering wheel shaft etc.. But sound
still there when turning..
A very soft but audible sound.. This is the best i can explain,
pls help.. Thanks all in advance first...
Just hope to find someone who has repaired this problem
before.. Thanks..
Re: F10 steering kok kok sound
steve9733;1017579 said:
Hi all brothers,
sometimes..
before.. Thanks..
maybe steering rack up lorry soon?
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
PI or PML?
PML go bang table.
PI go bang balls.
Kidding.
Let R2D's Rodney take a look.
Possible suspension mount BEARING up lorry.
Got it twice with my E60.
I went Munich n they lub . Still got problem.
Happens in morning only.
My initial thought was to lud the bearing from the strut tower opening.
After that sound gone for few days ... but come back a while later
Morning kok kok sound, at night got sound? Piak piak sound? :)
Thanks to all brothers who replied.. Will check those causes..
Thank you again..
did u do any suspension mods?
agree with jason8822, check your wheel bearings first
suggestion - add a "CHIANG" and you will have Chinese opera - tok tok chiang!
it's probably the spring and spring mounts. nothing serious so don't bother.
note: if it's the wheel bearings, symptoms will not be dependent on turning of wheels.
i have the kok kok sound each time i go up mscp ... it's the suspension
i have to go real slow so that the car front body is "nicely" lift up to the floor ... especially while turning up
i suspect the suspension (strut mount) was not fasten properly but everything seems install nicely leh
It kok kok.... not tok tok wor. Hehe.
Could be Strut mounting knocking against strut top. U could try to incorporate a thick rubber in btw them.
Kok kok.
Tok tok.
Tiak tiak.
Pika piak.
Same same...
Rabid,
not wheel bearing, SUSPENSION MOUNT BEARING
once upon a time i changed to KW Street Comfort and drive a lot on bad road
then finally kok kok kok sound came
ws change for me to M3 bearing (sibeh sart ?) but 6 mths later also kok kok kok and change to dunno whatever bearing
if this case, then most means the mounting nut loose which is very unlikely case
Actually it could b those plastic plastic rubbing against each other lah. Mine when i step acc n realease suddenly also got those tiak tiak kok kok n piak piak n biang biang sound. I also heck care. Though it cum frm the rear aircon side. Bt suspension part can check lah... go kp since under warranty bro
Tot I was e only one with noisy pedal. Tot it was made of wood when I first collected my car.
