E92 320i Coupe 2010 model
ROYYY
Hi bros and sis,
Hope you guys can answer me these few questions of mine;
1) what is the common issue for E92 320i (2010) model
2) what should i look out for when i am buying it?
3) is this model a problematic ones? or reliable?
4) will you recommend me to buy this model based on your knowledge?
Probably got to check for engine oil leaks, coolant leaks, gearbox malfunctions, worn undercarriage bushings, controls arms, shock absorbers. There will probably be plenty of wear and tear for a 8-9 year-old e92. Be prepared for fork out quite a bit, unless the last owner has been diligent with replacing these items.
