E90 PFL power window
tien1207
anyone know encounter this, window winded down unable to comes up anymore. need to replace the whole motor?
Re: E90 PFL power window
HI Tein1207,
The most likely part you require is the window lifter, as this is a common problem with the e90. Another possibility is the motor, do get it checked at a workshop to confirm.
Eng Soon Auto
Common issue. Happened to my BOTH rear left and right side - just 2weeks apart! Most likely the window lifter assembly.
Try pressing on the power window buttons and listen for the motor sound. If you can hear the motors working, there's a good chance that they are still good.
Also, if the lifter is broken, u may be able to use your hands to physically pull up the window. Do that and place a suction cup at the bottom of the window to prevent it from falling back down as a stop-gap measure. With the rain these days, not advisable to drive around with the windows down.
I bought my window lifter replacements from the nice people at Eng Soon, and got them replaced at my regular workshop. Should be a small issue.
Red_Bean_Bun;1095633 said:
Get an audio shop to open it up and have a look ...... gives you clarity.
Ya la, so many possibilities as mentioned above by the responses...go open up to check is the most basic thing.
Unless its the last possibility...got ghost
settled! got the part from Eng Soon, just replace the lifter. Thanks for all the advise.
i have it fix by Mr tan at only 120 dollars after my left rear window cannot activate.you guys can call him at 90069797.he will provide on site repair. took me only 15 mins to get my window done.warranty i think is 6 months,
Wow! That's cheap and good service! I got the part from Eng Soon and got workshop to fix it up. The lifter itself is about that price you mentioned. Original part though.
Do check the FULL functionality of your power window after replacement though. Initially, workshop tried to use an after-market part and after the window was wound down fully, I had to press the button twice before the window can come back up. Not a huge issue - but still a nuisance. Replacing it with the original part bought from Eng Soon solved that issue.
Was the $120 inclusive of parts?
$120 is using original parts or Taiwanese parts?
using recon parts provided by him. i using about 8 months already so far so good.
Gotta compare apple to apple. My understanding is that some of these parts are not OEM but from Taiwan.
