e46 320-54,000 km. What to change?
zennie
I just got a used 320i e46. Auto. Just changed out transmission fluid, power steering, coolant, rear differential, and right two 'regulators' for my power window.
What are the other things that would need to be changed as a 'preventive' maintenance?
How about any impending things that I would need to be changed and how about tell tale signs?
How about the belts? How many are there in total, when should they be changed, and how much would the damage be?
Car is 3 years old. How long does the radiator last before i starts puking coolant out and any tell tale signs? Battery? bushings? Steering rack? What else? Just need to be prepared...my first used car. :confused:
I noticed a slight WOOOOO sound coming from the REAR, or it could be in the middle. Not entirely sure. It is NOT the tires, but it is definitely something that sounds only when the car is moving. Could it be the bearings? Or is it common for e46s to have a slight hum? You can hear it when you're cruising with no throttle as you won't be able to hear it when you throttle because of the engine/exhaust. Any ideas?
Re: e46 320-54,000 km. What to change?
Aircon and cooling system will up lorry ard 3 yrs time. Top hose, radiator, coolant tank, compressor. Yr shock mounts too. confirm flattened by now.
Oil gasket, oil leak, etc.
Theres a sticky thread on E46 maintenance...pretty useful..
Damn, I just changed my shocks and springs without changing the shock mounts! How much do they cost and how much would labor cost? And what are the tell tale signs that they need to be changed? Are they the rubber part on the top of the shocks?
Where to find that e46 maintenance thread? Can't seem to find....
