E36 323/325/328/M3 Turner Motorsport Oil Cooler Kit - Stage 2 with Euro Oil Cooler
Blitzer
Part #: E36OILCOOLERKITST2
The TMS Stage 2 Oil Cooler Kit takes the benefits of the factory oil cooler and housing in Stage 1 and adds the TMS-exclusive HTP oil lines. This makes it possible to use the factory oil cooler with a supercharger or a racing alternator pulley. This is possible because the oil lines are routed away from the front of the alternator and alternator pulley.
The TMS Stage 2 Oil Cooler Kit uses mostly factory BMW parts to maintain the same clean appearance and performance you would expect if it was installed by the factory. The HTP lines (High Temperature Polymer Braided) oil lines are better than a rubber or stainless steel line. They are non-abrasive, unlike stainless lines, so they won’t cut into power steering or coolant hoses. By providing essential hardware with this kit the final result is a hassle-free installation for you, making this an ideal kit for a street/track car.
This kit can be fitted to any US spec 6 cylinder E36 BMW, including M3, 325i, 325is, 328i, 328is, and 323is (sedan, coupe and convertible).
This oil cooler system incorporates the Euro M3 oil filter housing which has ports for the delivery and return lines of the oil cooler. The internal pathways of the filter housing are designed for the oil to flow out of the housing, into the cooler, and then return to the housing. The US housing is not setup for any of this, as the oil just runs straight into the filter and onto the engine. Also, the Euro housing has an integrated thermostat to bypass the cooler at lower temps (who needs cold oil when the engine is cold?). We use the system from the Euro E36 M3, so all parts are guaranteed to fit and look as it would, had the car left the factory with it installed. Our products are engineered to work as a complete system, we do not take shortcuts – no leaks, no fitment problems, and as always superior performance.
Parts included:
Original BMW oil cooler (from the Euro E36 M3),
TMS custom built HTP oil lines with -10 fittings,
2 AN-10 oil line adaptor kits,
a BMW Euro E36 oil filter housing, brackets to mount the cooler to the bottom of the stock radiator (TMS exclusive!), and instructions.
Item is brand new. Bought at USD 1200. Asking SGD 1200 only.
@9665 3300 to deal pls.
