Correct offset for E90 18" rims
D_Iceman
Thinking of ordering a set of 18" wheels for my E90, need help to see if anyone can provide the correct offset for what i want.
I'm looking at 18X8 fronts and 18X9 rears. I probably might go for a brake upgrade in the future. Anyone can help with the offsets?
Thanks
Re: Correct offset for E90 18" rims
Factory stocks set up for 8 n 8.5 J are +34 n +37 respectively
And for one of their rims with 19in set up 8*9 Js are +37 and +39 respectively
So for your case if u wanna go for 8 * 9J , I suggest you go anywhere between +30 to +34 front AND +32 to +37 rear
I have a set of style 124 with 8x18 front and 9x18 rear for sale including PS2 tyres. Interested please PM.
That 124 is for E39 and E60 only.
thanks for the info. is the offset you provided gonna flush the rims with the wheel arch?
If u can get the rims with the lower (more negative) offsets then they should look much better or rather flushed to the fenders.
Where is the pic?...............
Just wanna share my experience.
I'm using 18x8 for both front and rear cos' I want to rotate my tires. But, I've installed Eibach spacers on the rear to flush the rear wheel to the sides. Furthermore, with Eibach pro-kit springs, there's no rubbing on the rear fender. ;-)
Thanks for the info.
That's an interesting and probably cheaper solution. I do about 3-4k kms a month, might be a good idea though i like the rear rims to be deeper.
How's the eibach springs ride quality? I'm thinking of the KW Variant 1.
